Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Table Saw Blade Replacement.
Thread Tools Display Modes
Old 09-17-2005, 08:05 PM   #1
Del Delaplante
Jr. Member
Del Delaplante is on a distinguished road
Question Table Saw Blade Replacement
Recently purchased a Freud Diablo 10" table saw blade. Since installing it I seem to be getting an inordinate amount of saw dust coming out the top of the table. The blade seems to be running true, not wobbling or vibrating. Can anyone advise me as to what might be causing this problem. Thanks in advance.
Del Delaplante is offline   Top - Reply with Quote
Old 09-18-2005, 08:42 AM   #2
kp91
Forum King
kp91's Avatar
Could have to do with the geometry of the saw blade. Depending on the number of teeth, gullet size on the blade, or the antivibration grooves, that may be the source of your dust. A zero insert throat plate for your 90 degree cuts may cure your problems.
1 John 1:9
Old 09-19-2005, 05:34 PM   #3
Del Delaplante
Jr. Member
Thanks Doug will try that.
Old 09-27-2005, 05:42 PM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Del, The Diablo blades are often thin kerf blades. This means the steel plate is actually thinner than on standard blades. My definition of why you are getting more dust airborn is what I call the "paddle boat effect." The cutting tips with the narrower blade seem to throw up more dust, similar to the way a paddle boat moves through the water. A zero clearance plate will be a big help, but a dust collector will show the biggest improvement. (I love my Diablo blades!)
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 1 07-08-2007 05:06 PM
Table saw blade guard? Birch Tools and Woodworking 1 04-21-2007 11:56 AM
Table saw blade and adjustment ? rh111 Starting Off 1 11-27-2006 08:31 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
