Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Scrap wood and paint stripping.
Thread Tools Display Modes
Old 11-22-2005, 11:32 AM   #1
Bruiser
New Member
Bruiser's Avatar
Bruiser is on a distinguished road
Default Scrap wood and paint stripping
I have some scrap that has one some two coats of paint.
If I want to make something should I strip all the wood first, some of which will end up as more smaller scrap and wasted stripper. Or cut to fit then strip paint and sand?
I'm thinking the paint left on is going to mess up my measurements.
Bruiser is offline   Top - Reply with Quote
Old 11-22-2005, 07:13 PM   #2
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Bruiser I would strip them first then build your shelves and the question for the thread I'd use some dado cuts for your sides for support. Makes the shelves more stable. I use glue and brads for mine. Most of my shelves are made from white pine. They hold up pretty well with my 3' spans.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 11-23-2005, 09:56 AM   #3
jerrymayfield
Forum Geek
Be sure to follow the instructions on the stripper,most strippers contain wax and this has to be removed. If you are ever in doubt about which stripper to buy, get the one that is the heaviest. It contains the most MC-nasty stuff but the best stripper.
Regards
Jerry
Old 11-23-2005, 11:29 AM   #4
KENNETH KIDWELL
Forum King
KENNETH KIDWELL's Avatar
KENNETH KIDWELL is on a distinguished road
if you have a thickness planer you can try to plane the paint off i did on some wood i had and it worked great unless you have a thickness issue and cant loose any extra
One good turning deserves another.
KENNETH KIDWELL is offline   Top - Reply with Quote
striping painted wood wil141 The Finishing Touch 6 06-12-2008 12:20 PM
Wood shape help please ColoChris Starting Off 16 10-03-2007 10:18 PM
What is the best wood to get a clean routered end-grain? bekandcurt Table-mounted Routing 17 07-03-2007 12:46 AM
Paint or Poly? -Sam- Tools and Woodworking 6 02-22-2005 03:55 PM
scrape wood router porjects? reible General Routing 9 10-06-2004 02:11 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
