Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - My template project.
Thread Tools Display Modes
Old 11-22-2005, 01:51 PM   #1
Junior
Junior is on a distinguished road
Default My template project
Hi guys. I'm new here so please bear with me.
I am building my second poker table right now. The first, I made all my cuts using my Jigsaw (which was a pain in the butt, and made very ugly cuts). This time I am building a template, using my new Porter Cable router, out of MDF that will be placed over a sheet of plywood allowing me to place my router in the grooves of the template and make accurate and consistent cuts.
Here is my problem. I will be cutting the actual poker table using a 1/4" upcut spiral bit, therefore, I need to cut the template with something slightly larger. I can't find anything "slightly" larger. I can find larger, but I don't want the slots to be too big. And, once I find that slightly larger bit, I also need a bushing guide that will go over my 1/4" upcut bit and the outside of the bushing should press against the inner edge of the slots in the template.
I can't find either of these!???? I'm not sure what to do. Where do you guys buy your bits from? Is there a such thing as a 5/16" upcut spiral and a bushing with an inner diameter of 1/4" and outer of 5/16"?
I've tried searching the web and couldn't find anything. I was hoping someone here with a bit more experience could point me in the right direction.
Thanks in advance for your responses.
Junior is offline   Top - Reply with Quote
Old 11-22-2005, 03:00 PM   #2
rh111
Forum Geek
rh111's Avatar
rh111 is on a distinguished road
Just a few places that come to mind.
www.holbren.com
www.mlcswoodworking.com
www.rockler.com
www.whitesiderouterbits.com
Those are just a couple of sites to look at that come to mind. I have experience with a couple of those companies and never had any problems. It's a place to start and go from there.
It's all good till it's no good anymore.
rh111 is offline   Top - Reply with Quote
Template Toms Latest project template tom Portable Routing 15 07-05-2005 05:10 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
