Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - carbide bits & key stock.
Thread Tools Display Modes
Old 12-22-2005, 04:48 PM   #1
moreorles2000
Dedicated Member
moreorles2000's Avatar
moreorles2000 is on a distinguished road
Default carbide bits & key stock
i would like to know if key stock can be used as guages when setting depths. i havent made anything other than a couple of signs & was wondering if they can be used other than not being brass.
and also are h.s.s. & carbide bits used in a machine shop the same as
used for routing wood.
les
moreorles2000 is offline   Top - Reply with Quote
Old 12-22-2005, 05:10 PM   #2
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
HI and merry christmas
Yes you can use Key stock or any other known dimension for setup. The brass guages
are not hard like the steel key stock and if by chance if a guage was to hit a carbide bit, there is less of a chance of the bit being damaged.
A half in is a half inch steel or brass.
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
An alternative way to hold stock harrysin Guide Bushings and Templates 5 02-18-2007 02:47 PM
Solid Carbide Bits - More likely to loosen? Chris H Router Bits - Types and Usage 2 01-12-2007 04:46 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
sharpening bits..... reible General Routing 4 09-19-2004 09:34 AM
