Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Working with radius.
Thread Tools Display Modes
Old 01-03-2006, 12:31 AM   #1
MiamiSnookII
New Member
MiamiSnookII is on a distinguished road
Question Working with radius
Hello everyone,
I am in the process of buidling a set of Adirondack chairs. In various parts of the plans it calls for a curve based on a specific radius. For example the curved back support calls for a 32.5" (R = 32.5" TYP (NTS) ).
What does this mean and how do I draw that radius. Other than getting a 32.5" piece of string and drawing it out I have no idea how to draw these curves. Is there a better way or is the string the solution?
Thanks,
Peter
MiamiSnookII is offline   Top - Reply with Quote
Old 01-03-2006, 08:20 AM   #2
Gilbear
Supreme Forum King
Gilbear's Avatar
Gilbear is on a distinguished road
Don't know how others have handled large radii, but I've used the string routine (can be a little wobbly though) - also strip of cardboard with hole punched through for pencil and radius point (a little less wobbly - reinforce the radius point hole so it doesn't enlarge on you) - I have access to cadd software with a large format plotter and can draw and plot out very accurate full size templates, which is what I normally do.
By the way, "NTS" usually means "Not To Scale", referring to the plan drawing.
If it would help, you could e-mail me the plan and I could calculate "chord offsets" or middle ordinates for you that would allow you to lay it out without a bean compass.
Gilbear is offline   Top - Reply with Quote
Old 01-03-2006, 08:22 AM   #3
Gilbear
Supreme Forum King
Gilbear's Avatar
ooops - BEAM compass
Old 01-03-2006, 05:09 PM   #4
Hamlin
Supreme Forum King
To draw out radius circles or half circles, the best method is to use a straight piece of wood with a nail at one end with an adjustable holder to hold a pencil to draw the circle(s). As mentioned above, using the string method, you don't get a true or a very accurate circle.
Ken
Old 01-03-2006, 06:27 PM   #5
mikehillclimber
New Member
mikehillclimber is on a distinguished road
Unless you have a very large compass or a set of trammel points, the string approach is simple and accurate enough for an Adirondack chair. If the pencil is placed in a knotted loop and the other end wrapped around a small pin and held tight, the slight change in radius-length will be negligible. But, after drawing the arc I would backtrack to ensure that the length did not change.
Cut out the template (masonite/hardboard/plywood) and use it wherever called for.
mikehillclimber is offline   Top - Reply with Quote
Old 01-07-2006, 10:20 AM   #6
MiamiSnookII
New Member
Thanks for the advise,
You are indeed correct, using the string created problems with consistency. Even though the Adirondack is very forgiving, I am using this project to learn and establish some very good and basic wooworking skills. So I will probably end up overdoing it a bit.
I went ahead a picked up a set of trammel points attached to a piece of wood. I assume that is the similar to a beam compass.
My first step is cut out the template with either hardboard or plywood ( I have to look into masonite, I don't know what that is, but if it is a bit more water resistant it may be the way to go).
Again, thanks for the help.
Peter
Determining a radius cut RoyBullets Jigs and Fixtures 7 06-23-2008 08:10 AM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 05:51 PM
You might be a wood working / Router junkie if...... Noddy Lobby 10 09-12-2007 03:09 AM
3/4" Radius roundover bit with 1/4" shank chrisogrady General Routing 8 04-01-2005 08:08 PM
Building a New Router Table-What's the Ideal Working Height? gerrym526 Table-mounted Routing 6 02-19-2005 11:13 AM
