| Starting Off If you're new to any power tool and/or woodworking technique, or you just have some general questions about starting a project, feel free to post your questions here! |
| | #1 |
| Registered User Dedicated Member | I have a 10" Craftsman Table Saw with the original blade on it. I rarely use it due to it being difficult to get square cuts and the cuts are a little rough. Should I be looking at getting a new blade? If so, what kind? What does the number of teeth have to do with the type of work/cuts? Thanks! |
| | #2 |
| Registered User Sr. Member | Bottom line Shane is, Few teeth for ripping. (speed) Many teeth for smooth cross cuts. (Finish work) Combination blades do (OK?) on most things but not great on anything. Like everything in life there is a trade off. Hope that helps. CB
__________________ I've sanded so much my fingerprints are gone! |
| | #3 |
| Registered User Dedicated Member | Thank you so much. That's what I thought, but wanted to be sure before I went out and bought something. |
| | #4 | |
| Retired Moderator Forum Geek | Quote:
You might also check to see if your fence is square, the Craftsman that I got from my dad and the one my brother owns has twisted fences. Not sure how this happens but my brother was able to take the twist out of his. They are both older saws.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ | |
| | #5 |
| Registered User Supreme Forum King | If you're not getting square cuts, another thing you may check into is to see if the blade is squared with the table itself. |
| | #6 |
| Registered User Supreme Forum King | One of the best and easiest way to improve a saw is to get better blades..... but as was stated the blade needs to be aligned to the table (miter slot) and if it an older saw the bearings can be worn giving you less then perfect results. It is also importain to use the right blades for the job. A rip blade for ripping, a cross cutting blade, and plywood blade are good first picks. A combo blade is handy for general purpose cutting and ruff cutting....... If you don't know how to check for blade to table alignment let us know it is simple to check and while I can't tell you how to adjust the saw I bet someone here can. Ed |
| Router Table Help Which One! | bigroccrek | Table-mounted Routing | 25 | 04-08-2008 11:57 PM |
| Delta 10" Table Saw Blades | Thrifty Tool Guy | Tools and Woodworking | 0 | 01-30-2008 09:27 AM |
| First and only (I hope!) Router table | CanuckBeaver | Table-mounted Routing | 11 | 07-25-2007 03:45 PM |
| Dado blades and other table saw specialties | Mike | Tools and Woodworking | 3 | 01-05-2005 09:07 PM |
