Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - 3 hp router.
Thread Tools Display Modes
Old 01-15-2006, 02:03 PM   #1
ShaneB
Dedicated Member
ShaneB is on a distinguished road
Default 3 hp router
I am looking to upgrade from my 1 3/4 hp PC router to something bigger for raised panel projects. Do I need to go to a 3 hp machine or would the 890 series be large enough?
ShaneB is offline   Top - Reply with Quote
Old 01-16-2006, 09:22 AM   #2
jerrymayfield
Forum Geek
You could use the smaller router,making several passes,but I would buy a 3hp.soft start,variable speed ,and if possible one that can be adusted and bits changed above the table.If you get what you what you really need it only hurts once, not every time you use it.
Good Luck
Jerry
Old 01-16-2006, 09:56 AM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: I had a PC router, a PC690, it isn't big enough for the raised panel cutters. I bought a PC7539, soft start varible speed to do the raised panels. The throat of the router should be big enough to acccomodate the large cutters. If you use a smaller router it is running to fast for those large bits, they should run 10K to 12K rpm.
Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 01-16-2006, 10:50 AM   #4
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
The series 890 will work fine to make raised panels.
Rick and Bob
The Router Guys
Old 01-17-2006, 08:19 PM   #5
ShaneB
Dedicated Member
Thank you all so much. You've been great help. I am still a little torn though. My gut tells me to spend the extra $100 for the 3hp, but logically I think the 890 would be enough. Someone please convince me!
Old 01-17-2006, 08:21 PM   #6
ShaneB
Dedicated Member
What is the "soft start" feature?
Old 02-25-2006, 06:43 AM   #7
del schisler
Forum Geek
del schisler is on a distinguished road
it starts off real slow to fast start routers with out this starts off at full speed del schisler
del schisler
del schisler is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
