Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Inside corners on letters.
Thread Tools Display Modes
Old 08-06-2006, 07:13 PM   #1
petersenj20
Sr. Member
petersenj20 is on a distinguished road
Send a message via MSN to petersenj20
Default Inside corners on letters
I am new to using a router. Mine is a Dremel router attachment.
How do I cut the tiny inside corners on letters Like an A or even the square corners on an E?
Joe
petersenj20 is offline   Top - Reply with Quote
Old 08-06-2006, 07:29 PM   #2
fibertech
Forum Geek
fibertech's Avatar
fibertech is on a distinguished road
Send a message via AIM to fibertech
Welcome Joe,
Use a small wood chisel. If you want to get elaborate, there are spring loaded chisels that you strike with a hammer. The first method that I described should serve you. -Derek
fibertech is offline   Top - Reply with Quote
Old 08-06-2006, 08:25 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
You may want to drop a P.M.or a email or a post to Terry and ask him for a tip and how he got his so sharp in the corners.
Almost all of his letters have sharp corners and he said it was a free hand router job.
See his post below.. , he did a great job on his sign.
http://www.routerforums.com/showthre...0796#post30796
Bj
Old 08-06-2006, 08:32 PM   #4
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Visteonguy is on a distinguished road
Hi Joe,,
Derek is right about using small wood chisels, I use them some times,,, I also have used wood carving tools in the same manner.
Most of the time, I use an air powered die grinder, with small rotary cutters and use it like a micro router. It works for me. I have several of them, that I bought from Harbor Freight, You can get them for about $14.99 and I have used the diamond point sets they sell for about $3.99 for a set of 20 different shapes,, How ever they are a pretty fine diamond grit and load up fast, they will not take a lot of material out,, if you look in wood carving catalogs,, you can find the same kind of cutting tools that are in Ruby and they will cut better, I only use them for sharpening up the very tight inside corners,, I have found some very small burrs that have 1/8 inch shafts that fit the air die grinders,, those work very nice also, and remove more material faster then the diamond or Ruby cutters,, but there are NO hard fast rules,, ya use what every ya find and works for you to get you where you want to go,,, Main thing is to just have fun making your signs,,
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline   Top - Reply with Quote
Routing out inside of a 3/4 x 2 x 4 DavePowers General Routing 5 04-14-2008 08:43 AM
Routing a decorative edge on the inside of a faceframe? Woodworker 52 Portable Routing 2 01-29-2008 01:00 PM
Poly the inside of furniture? WoodyRon The Finishing Touch 4 09-11-2007 08:28 PM
Routing a decorative groove on an inside curve HanDan General Routing 2 03-15-2006 03:43 PM
Cutting out large letters RodLloyd Jigs and Fixtures 6 11-24-2004 12:24 AM
