Go Back   Router Forums > General Woodworking > Starting Off
Starting Off If you're new to any power tool and/or woodworking technique, or you just have some general questions about starting a project, feel free to post your questions here!
Thread Tools Display Modes
Old 09-07-2006, 11:44 AM   #11
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Yep, no rejects, I have used about 12 of them so far they are all the same
They did come in a plastic bag and I did count them just to make sure of the total and it was over by 3 but that was fine with me. I didn't count the screws but they look ok also.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 09-12-2006, 06:33 PM   #12
rh111
Forum Geek
rh111's Avatar
rh111 is on a distinguished road
What is the preferred material for making drawers? Is 1/2" ply acceptable for the sides and back? Or, would lumber be better? How about the bottom?
It's all good till it's no good anymore.
rh111 is offline   Top - Reply with Quote
Old 09-12-2006, 07:27 PM   #13
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi rn111
I like to use 1/2" SOLID wood for the drawers it's one of the 1st thing people look at
When they check your work out and plywood will always look like cheap const.plus if you put in dovetails or box joints they just don't come out clean even if you use birch plywood.
I do use 1/4" or 1/8" veneer plywood for the bottom part of the drawer because you don't see the edge of the plywood and it's stable and it's strong.
(1/8" for small drawers 4" x 6" or smaller)
You can use 3/4" solid wood for the drawers, if you round over the top edge, that makes it look smaller and not as bulkey..I will some times use a 1/2" bead bit that trims it out nice.(on the top edge)
Note***if you use a bead bit (bull nose) or thumb nail bit stop just sort of the front panel about 1/2" in this way you can slide the drawer in without a front panel and it will look right. (true and sq.to the face frame) or the case.
http://www.grizzly.com/products/c1218
http://www.grizzly.com/products/c1219
http://www.grizzly.com/products/c1029
http://www.grizzly.com/products/c1031
Hope this helps
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 09-28-2006, 05:16 PM   #14
rh111
Forum Geek
rh111's Avatar
Took bobj3's recommendation on the hinges. Have put 2 doors up so far and good success. Not bad for the price.
Does anyone have some advice for drawer slides? Was looking at the Knape and Voght 1284 series (must be white according to better half). I had a suggestion from some one on Lee Valleys slides. I was leaning toward lower side mounts unless someone has a strong suggestion otherwise. Does anyone have a good quality source for a slide that does not brake the bank? I am only needing 6 sets of slides, so a bulk pack is kind of out of the question.
Thanks for all your help!
Old 09-28-2006, 08:37 PM   #15
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi rn11
How about Grizzly, you can buy one or as many as you need at a good price.
H4526 Regular Drawer Slides - 22" at 3.25ea. in white
It's a bit lower at 6.
http://www.grizzly.com/products/h4526
http://www.grizzly.com/catalog/2006/Main/423
http://www.grizzly.com/products/H3292
http://www.grizzly.com/products/h3293
Yep I know Grizzly link AGAIN , but they do have lot that you and I need in stock.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 09-29-2006, 11:48 PM   #16
rh111
Forum Geek
rh111's Avatar
Took your advie once again and looked at Grizzly. I noticed that they are shop fox brand. Then the light bulb went off. I have a shop fox dealer right up the road. Stopped by there today. They are placing a order next week and I can order thru them when they order in tools for no freight. Not to mention since it is a tool supply store, my work and employees buy off of them. They got me slides for about a little less than grizzly, but with no freight.
Thank you bobj3 for all your help!
Old 09-30-2006, 12:21 AM   #17
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You're Welcome rh111
Glad the light bulb went on and you got them on the way to you.
That's what's neat about the Net with the on line catalogs.
Post a snapshot or two when you get done I'm sure others would like to see it .
Have a great weekend Mate
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
