Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Router Table.
Thread Tools Display Modes
Old 09-18-2006, 05:54 AM   #1
mks130
mks130 is on a distinguished road
Default Router Table
I have seen the Router Workshop program on PBS. I am amased at how easy the setups appear to be. Does anyone have the specs/plans for the router table and fence that is used on the show?
mks130 is offline   Top - Reply with Quote
Old 09-18-2006, 06:17 AM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: The router table is available from Oak-Park, a sponsor of this forum. They sell the parts to build one, and also a plan. You can reach them at Oak-Park.com.
Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 09-18-2006, 06:21 AM   #3
del schisler
Forum Geek
del schisler is on a distinguished road
Default router workshop table and other item's
here is the web site for all you will need http://us.oak-park.com/catalogue.html?list=BYOT--
del schisler
del schisler is offline   Top - Reply with Quote
Old 09-18-2006, 10:17 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi mks130
1st. let me say the Oak-Park router system is one of the best on the market today
THAT SAID
BUT I try and tell it like I see it, and this is just my 2 cents
The Oak-Park system has a error or two in it and it's a bit high in price but again it's a easy one to use and setup.
They have many,many jigs you can buy for the Oak-Park systems.
The 1st. error if you want to use the big bits you will need to get two base plates,the one that has a 3 1/8" in it and it's a bit small because many of the panel bits are bigger that 3 1/8" now days.
Then you will need to get a base plate with a 1 1/2" hole in it so you can use the brass guides on the router table.
They don't make a insert for the 3 1/8" base plate,so this means you will need to have two routers or take the base plate off and put on the one with the 1 1/2" hole in it.
They have a new base plate with a vac.pickup but it's the same as the others.
It's hard to put out 170.00 bucks for a base plate and some plywood with a hole in it and a fence and other parts but it's a bit high in price I think.
But again if you go with the Oak-Park Router system go all the way and you will be glad you did.
The best way ,I think is to get a base plate with all the bells from the get go and make your own top and cabinet,they sale many types of base plates and you can do a search on Google/Froogle.com for them.
I will not push the one I like because it's up to you and it's your money not mind.
But do note you get what you pay for when you buy tools... so buy the best you can.
If you don't want to make one(router table) you can find many that are made at the Mfg.
Same thing froogle.com for them
Good Luck with your quest..
Bj
bobj3 is online now   Top - Reply with Quote
Already Problems neuschu Introductions 7 01-22-2008 10:32 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 11 07-25-2007 02:45 PM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 8 05-22-2007 06:42 PM
