Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Router as a Jointer.
Thread Tools Display Modes
Old 09-18-2006, 10:34 AM   #1
oldnewbie
Forum Fanatic
oldnewbie's Avatar
oldnewbie is on a distinguished road
Default Router as a Jointer
I'm just starting out, and thought I'd try my hand at something simple like small, crafty-type shelf units for practice. I would like to joint some boards together to make them wider. How do I set up my table fence to accomodate this, and what is the best bit to use?
oldnewbie is offline   Top - Reply with Quote
Old 09-18-2006, 11:18 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Oldnewbie
The best bit to use is the Flush Trim bit, this is because of the skew angle on the cuttters on the bit.
It can be 1/4" or 1/2" shank but it's best to use 1/2".
Pop in the bit and place a some double stick tape on the out feed side of the fence (left side) don't take of the white part of the tape, also make the tape about 12" to 14" long, then take a brass bar or a true block of wood and move the fence till the block just will just kiss the bearing on the top of the cutter (use the left side of the fence to set it) now lock the fence down and run a pass about 3" long on the side of the stock, now check the stock,it should be clean and sq.
This will take off about .010 and should give you a true sq. glue edge,you may need to run it by more that one time if the stock has any nicks on the edge.
Besure to hold the stock up to the out feed of the fence when you run the pass this will help with the snipe at the end of the pass.
You can cut your stock a bit long if you are getting a big snipe at the end of the pass and then just cut off the bad part.
Hope this helps
Bj
Old 09-18-2006, 12:40 PM   #3
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
To avoid snipe, router bits cutting edge has to be exact as out feed sub base.
http://www.woodshopdemos.com/rtrplnr.htm
Router is still my name is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
