Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Keeping something square when gluing?.
Thread Tools Display Modes
Old 10-29-2006, 02:49 PM   #1
ygdrasil54
New Member
ygdrasil54 is on a distinguished road
Default Keeping something square when gluing?
Just finished gluing up all four sides of a toybox (first time gluing up something like this) and after drying, both end pieces came out of the clamps slightly out of square.
They were in square before the clamps went on, but as soon as they do, you lose the ability to put the framing square back on to recheck it. It's not going to help me this time, but I'll know better the next.
Any suggestions?
ygdrasil54 is offline   Top - Reply with Quote
Old 10-29-2006, 03:51 PM   #2
Hamlin
Supreme Forum King
Pending of the size of the toy box, there are small "squares" you can purchase. You could also make your own.
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 10-29-2006, 06:31 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tom
All is not lost, I think we have done the same thing now and then
What I do to fix this error is make a 2 BOXES and tap then in to place on the botton on the toy box on ea.end of the toy box (to hold/support a new bottom or floor) you will need to tap in a stick( 2 x 4 works great for this job but don't just try and use the 2 x 4s the small box is the key) to push them in to place,then pocket hole the box to the old floor once it's sq. it will take a bit to unrack it but it will work.
You can make the boxes and use them on ea. end(inside) with a lid on them for Small toys that always get lost on the bottom of toys boxes.
You also may need a stick from corner to corner(to the small boxes inside) (with 2 45deg. cuts on ea. end.) to unrack it and hold it sq.
Hope this helps
Bj
Old 10-30-2006, 12:13 PM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
There are corner clamps to ensure you get a good fit, Rockler has some 90 degree angles you can attach to help hold your corners in place. Perhaps a different glue joint is in order? Other options include using biscuits for alignment, Fastening with either pocket hole screws or "Miller" dowels guarantee your wood will not shift.
Old 10-30-2006, 04:30 PM   #5
ygdrasil54
New Member
Thanks for the answers people. I got a raised panel set that came with a glue joint bit for my router table. It puts two tongues & grooves into the board edges.
The finished joint seems like it would do fine to me, but being a glue up rookie, what do I know?
Old 10-30-2006, 04:59 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tom
The glue joint bit is one of the hardest bits to setup and use on the router table, run many test boards b/4 you use it.
You will need to use a off set on the out feed of your router table fence (about 1/16" to a 1/32") just to start with. (the glue joint bit is a Advance router user item)
How to for the glue joint bit
http://www.woodshopdemos.com/cmt-gl1.htm
http://www.mlcswoodworking.com/shops...2/22tongue.pdf
Bj
TS blade with square corner cut? AxlMyk Tools and Woodworking 4 07-06-2008 05:20 PM
Miter guage not quite square S Bolton Tools and Woodworking 6 05-20-2008 08:28 AM
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
Square fence Drick General Routing 5 03-30-2005 02:17 PM
How to route 10" square in tabletop? Lee General Routing 16 12-27-2004 12:16 AM
