Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Sink trays.
Thread Tools Display Modes
Old 02-05-2007, 11:14 PM   #1
rh111
Forum Geek
rh111's Avatar
rh111 is on a distinguished road
Default Sink trays
I have an opening right below the sink but above the doors that I want to install some plastic sink trays into. I have looked at a couple of websites but found nothing that was remotely close to what I am after. I also am in need of the hinges so that will tip out. The trays that I want need to be 1 piece molded plastic. I don't want none of this cut to length as that is where we intend to store sponges and sink stoppers.
Does anyone have the low down for a supplier on this type of item?
It's all good till it's no good anymore.
rh111 is offline   Top - Reply with Quote
Old 02-06-2007, 12:07 AM   #2
labric
Sr. Member
labric's Avatar
labric is on a distinguished road
Hi rh111
In Canada, the tip out trays you are looking for, are available through Richelieu Hardware and there products can be seen on their website
For their General product lines:
http://www.richelieu.com/produit/index.php?lang=An
For their tip out trays "kitchen storage solutions":
http://www.richelieu.com/produit/ind...stom=1&id=3710
I have seen some Richelieu products sold through HD and others. Check with your local cabinet shop or millworking shop, they may have access to these products , if HD doesn't.
Good hunting!
Ric
Start Safe!!! Finish Safe !!!
labric is offline   Top - Reply with Quote
Old 02-06-2007, 08:11 AM   #3
rh111
Forum Geek
rh111's Avatar
bump
Old 02-06-2007, 11:42 PM   #4
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
http://www.rockler.com/CategoryView.cfm?Cat_ID=196
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
counter top sink hole cabinet guy Introductions 2 05-01-2008 09:49 PM
Counter Sink Bit Usage garycurtis Router Bits - Types and Usage 1 01-07-2008 05:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
