Hand plane chipping oak - Router Forums
post #1 of 12 (permalink) Old 05-20-2014, 01:33 PM Thread Starter
First Name: Peter
I've been using a plane for the first time and I'm finding that it gets stuck which can result in small chips. I think I must be doing something wrong but I don't know what. It seems to work fine on rough wood (oak), but once it gets flatter it starts to get stuck.
My plane is a Faithful one and the first thing I did to my plane was sharpen the blade. I'm doing very shallow cuts, if I retract the blade much further then it doesn't even touch the wood.
Any ideas what is wrong?
DrillingThrough is offline
post #2 of 12 (permalink) Old 05-20-2014, 01:57 PM
You could try going the opposite direction on the grain and try setting the chip breaker closer to the cutting edge.
post #3 of 12 (permalink) Old 05-20-2014, 02:17 PM Thread Starter
First Name: Peter
I've tried going in both directions and I think I'm going the right way. The chip breaker is already pretty close, but I could try moving it closer.
post #4 of 12 (permalink) Old 05-20-2014, 02:42 PM
Another thing you could try is a skewed cut instead of going square to the grain.
post #5 of 12 (permalink) Old 05-20-2014, 10:45 PM
You may also be trying to plane too deep....
Sydney, Australia
jw2170 is offline
post #6 of 12 (permalink) Old 05-20-2014, 11:47 PM
Country: Pakistan
First Name: Obaid
Carpenter12 is offline
post #7 of 12 (permalink) Old 05-21-2014, 05:29 AM
skiroy56's Avatar
First Name: Laurence
If you haven't done it, try waxing the sole to smooth out your strokes.
skiroy56 is offline
post #8 of 12 (permalink) Old 05-21-2014, 06:33 AM
I'm afraid Faithfull are very poor quality planes - you may never get it right. Oak is difficult too. The grain can run both ways. Also what size is it? Smaller planes may not have enough heft for the job on oak - hence getting stuck.
plus all the comments above may be true too!
Fraise is offline
post #9 of 12 (permalink) Old 05-21-2014, 07:40 AM
First Name: Buck
It could be that the bottom of the plane isn't dead flat. Very few planes out of the box are. It's a lot of work but what I have had to do with all of my planes is to sand them flat. Start with a 120 grit sandpaper on a piece of glass and work your way up to 500 grit. You should end up with a polished surface.
BOjr is offline
post #10 of 12 (permalink) Old 05-21-2014, 11:22 AM Thread Starter
First Name: Peter
I think it does run both ways in some places. I have looked in some places, decided that it runs one way, then looked somewhere else and decided it must run the other way.
It's a no 4, but my boards are very small. I've cut the boards to about 14" in length IIRC.
Human Verification
Outdoor untreated oak gates IAN1930 Project Plans and How To 7 04-14-2014 02:53 AM
Fenland Black Oak Table Project-5000 year old tree allbarknobite Lobby 6 10-18-2012 03:21 PM
raised panel oak cabinet doors bobshere Tools and Woodworking 7 01-13-2011 08:43 PM
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 55 06-17-2009 10:18 PM
Oak, Octagonal Drum Table. derek willis Show N' Tell 18 02-25-2009 09:20 AM
