Go Back   Router Forums > General Woodworking > Starting Off
Starting Off If you're new to any power tool and/or woodworking technique, or you just have some general questions about starting a project, feel free to post your questions here!
Thread Tools Display Modes
Old 08-06-2007, 10:05 AM   #11
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Any new signs in the pipe line?
Harry
harrysin is offline   Top - Reply with Quote
Old 08-09-2007, 11:58 AM   #12
Visteonguy
Forum Geek
Visteonguy's Avatar
Visteonguy is on a distinguished road
The 2 methods that I use to transfer letters to my work peice, when making a sign, start out the same as BJ and Jeff have mentioned,,, print them out from a word program on your computer,, then I blow them up to the the correct size I want to end up with,, but when I get to that point,, I just lay a layer of carbon paper first on the work piece and then lay the printed letters on top of the carbon paper. No need to cut them out, because its still one sheet of paper or several taped together ( If its too big to fit on one sheet of paper ) That way, the alinment will be just as perfect as it was as it came from your computer printer. Now all you have to do is run a pencil around the outside of the letters or image, remove the printed sheet and carbon paper and you now have your letters or image transfered to your work peice exactly as it was printed on the paper. I bought a box of carbon paper at an office supply store like Office Depot or one of their competitors, a box of 50 sheets cost me only about $4 or $5 a couple of years ago and will last a LONG LONG time,,,
The other method,, I learned about from taking some art classes at work. The instructor showed us the secret behind using a projector to transfer your letters or images to a work surface,,, that really opened up my eyes to that machine,,, anyone can be an artist by using that machine,,,
All you do is print out your sign as you want it to look like,, size is now NOT important, actually smaller is better now, because a smaller image will fit in the viewing area on the projector. When you get it to look like you want it, on a piece of paper,, lay it on the viewing surface of a projector and shine the image up on your work surface,, if you want it larger,, just move the projector back farther from the work surface,, smaller,,move it closer,, once ya got it the right size,,, just outline the image with a pencil and when you have all the information up there,, shut off the light in the projector and see if the sign has all the information you need it to have,,, once you are satisfied, take down your work piece and get started with your trim router and rout it out freehand.
With either of these methods,, you can make a sign say anything you want with NO templates.
Templates do have their uses however,, if you have to make several coppies of a particular sign,, then maybe its worth your time to go through the trouble to make up some kind of template for that sign,,,
I have posted a couple of these pictures quite a while back but they show the first method I explained, with the carbon paper. Then, on the blanet chest, I used the opague projector to lay out the stylized H on the blanket chest I made a few years ago. Both methods work great, the carbon paper is almost free, but there is the cost of the projector if you use that method, but if you have lots of stuff to transfer, its an item you will find very usefull.
cursive-lettering-im001499.jpg  cursive-lettering-im001503.jpg  cursive-lettering-im001504.jpg  cursive-lettering-im001507.jpg  cursive-lettering-im002218.jpg
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline   Top - Reply with Quote
Old 08-09-2007, 07:13 PM   #13
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Terry, thanks for all the photos. Beautiful work! I love that H on the mobile chest. Is that H carved in or scrolled and attached? My daughters name is Hailey and that is what I want to be able to do in a jewlery box lid. I don't know if it is possible with a template but I don't it's to small to do free hand, what do you think? Excellent work!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 08-09-2007, 09:13 PM   #14
Visteonguy
Forum Geek
Visteonguy's Avatar
Hi Corey,,,, Thanks,, for the compliments.
The H is carved in the boards of the blanket chest. If you look closely you can begin to see a rounded area around the H, because I laid out the H and then freehand carved it out to a depth of about 1/4 inch. then I used a disk grinder to grind back the wood on a taper back out to the surface of the boards of the chest. Then used a disk sander to smooth it even more to help hide the depression. They are about 1 1/4 inch thick boards so it was not a problem sinking the area some what. maybe I should have ground back the area farther to make it less noticable, but that was just a few days before christmas and that was the dead line,,, so it is what it is,,,
You can use that same method to route out some very small images,,, what you might try is setting up some kind of base on a dremmel rotary tool and find a bit that is small and agressive cutting,, It would be like having a "Mini" trim router and use it the same way as I have used the trim router. once ya have that,, you can do some very small letters,, I use a small air powered die grinder ( that I bought from Harbor Freight for about $15 ) with some 1/8 inch shank cutting burrs for tightening up the sharp corners of letters , I have some that come to a point,, that I can use to make perfectly sharp corners.
One thing about doing a sign or letter that small is you do not have to go 1/4 inch deep,, 1/8 or 3/16's will look very good on that size,,,
Sharp chisels also some times are good for cleaning up corners,, One thing about this game is ,, there are NO rules,, ya use what works for you to get the job done,,, and have fun doing it... thats the whole reason to be doing it in the first place.
Terry
Old 08-09-2007, 09:22 PM   #15
challagan
Supreme Forum King
challagan's Avatar
Thanks for all the tips... it's a beautiful project!
Old 08-09-2007, 09:26 PM   #16
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Originally Posted by Visteonguy
. . . .One thing about this game is ,, there are NO rules,, ya use what works for you to get the job done,,, and have fun doing it... thats the whole reason to be doing it in the first place.
AMEN
And what you did CLEARLY works for you --
BEAUTIFUL work.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 08-09-2007, 10:49 PM   #17
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Terry,
COOL, C O O L, C O O L !!
That's my kind of procedure...!
The KISS principle!
Great! Thank you for sharing!
Joe Lyddon is offline   Top - Reply with Quote
Old 08-09-2007, 10:55 PM   #18
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
The H is carved in the boards of the blanket chest. If you look closely you can begin to see a rounded area around the H, because I laid out the H and then freehand carved it out to a depth of about 1/4 inch. then I used a disk grinder to grind back the wood on a taper back out to the surface of the boards of the chest. Then used a disk sander to smooth it even more to help hide the depression. They are about 1 1/4 inch thick boards so it was not a problem sinking the area some what. maybe I should have ground back the area farther to make it less noticable...
Thank you for a Super nice technique!
lettering into wooden signs- HOW? moe Project Plans and How To 16 09-19-2008 10:49 PM
lettering guides Ken Noel Introductions 0 05-16-2008 01:07 AM
Carvewrite Lettering Question fishinfusion CNC Routing 10 06-13-2007 09:37 PM
lettering nightmare Birchwood General Routing 19 10-18-2006 09:52 AM
