Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Plexiglas Template.
Thread Tools Display Modes
Old 01-02-2008, 02:36 PM   #1
rmetoile
New Member
rmetoile's Avatar
rmetoile is on a distinguished road
Default Plexiglas Template
Hello all,
Sorry if this question is stupid... but
Does anybody know what if I use a template made of plexiglas instead of MDF? I plan to use a CNC to perfectly cut my templates (many many curves...) and I have a lot of 5mm plexiglas sheets. In normal use, I mean using a good piloted flush trim bit should I have particular problems ?
That would help me a lot.
Michel
rmetoile is offline   Top - Reply with Quote
Old 01-02-2008, 04:13 PM   #2
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Bonjour mon ami. Accueillir aux Forums de Routeur. Enough of that Michel cause I don't speak French. Welcome to the Router Forums. I'm not the expert, but you can use plexiglas, MDF, Plywood, or hardboard to make templates out of. Just make sure your template edges are as smooth as you can get them. So as not to transfer any inperfections on to your work.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 01-02-2008, 04:43 PM   #3
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
curiousgeorge is on a distinguished road
Hello Michel, Welcome! It looks like Dr. Zook has taken care of your question. By the way... the only stupid question is the one not asked.
George
If you can't fix it with a hammer, you've got an electrical problem...
curiousgeorge is offline   Top - Reply with Quote
Old 01-02-2008, 04:55 PM   #4
Hamlin
Supreme Forum King
Plexi-glass makes a perfect template. As Dr. Z stated, make sure the edges are smooth so as to not transfer any imperfections.
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 01-03-2008, 06:00 AM   #5
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
For use with male templates I can't foresee a problem though 5mm is probably thinner than I would normally use. A safer method would be to use female templates which would be no problem to make on a CNC machine, which raises the question, if you have access to a CNC machine, why not make the final items on it?
Harry
harrysin is offline   Top - Reply with Quote
Old 01-07-2008, 01:47 AM   #6
rmetoile
New Member
rmetoile's Avatar
Bonjour Dave,
Thank you very much for your answer. I'm going to make a test and post pictures of my results.
michel
Old 01-07-2008, 06:10 AM   #7
reikimaster
Forum Geek
reikimaster is on a distinguished road
Once you get the plexiglas template made and after you smooth the edges pretty well, you can run a torch along the edge and it will make it smooth as glass.
Of course you would want to experiment a little on some scrap to see just how much heat it needs to smooth out the edge. I've done this when bending half inch lexan sheets.
5mm might be a bit thin for this but.... worth a try. The edge is beautiful when it works right.
reikimaster is offline   Top - Reply with Quote
Old 01-07-2008, 01:07 PM   #8
rmetoile
New Member
rmetoile's Avatar
Default 5mm Plexiglass
Hello all and many thanks for your answers and advices.
About plexiglas thickness I agree 5mm is a bit thin so I will try 8mm or 10 that's should be better. The use of a torch to smooth the edge is a good solution. The small shop who will cut my templates use a laser CNC so in this case the laser act as a torch so edge is smooth as glass. They did a demo for me last friday (they have cut some letters for a logo) and I have to say that is very impressive : fast, clean and accurate. I like that technology! I will post some pictures.
mchel
Half Blind Router Template Question stevek433 Introductions 4 03-01-2008 11:17 AM
Mortise Template JDługosz Jigs and Fixtures 14 09-27-2007 01:32 AM
Template Routing FlyFAmerica Portable Routing 8 01-22-2007 08:57 PM
Hitachi M12V template guides? vwmowery General Routing 6 08-31-2006 11:51 PM
Template, how to make? smacmullin Jigs and Fixtures 2 11-08-2005 04:52 PM
