Go Back   Router Forums > General Woodworking > Starting Off
Rate This Thread - Router turning machine.
Thread Tools Display Modes
Old 04-04-2008, 06:24 PM   #11
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just two more snapshots
The pictures show how to make a lock for the index head so it can be used to put in flutes, by just sliding the router up and down the rails,, the index head has marks 1 to 24 that can be used to setup the stock from 2 to 12 flutes...just by chucking up just about any router bit,,any bit will do the trick...
router-turning-machine-0088.jpg  router-turning-machine-0089.jpg  router-turning-machine-0092.jpg
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/W...p_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
Floating Mortise & Tenon: A strong and Silent Joint
Old 04-07-2008, 02:46 PM   #12
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just some more snapshots,,,this one started out as a old cedar fence post that I pulled out of the firewood stack out back..
Play time to get the hang of all the setting on the router lathe tool..
I just can't justify buying a new wood lathe when this one can do it all plus some...and it's real quick with a pattern bolted on the front side of the tool it can copy and put on a taper quick and easy without making any firewood...
http://legacywoodworking.com/ProjectPlans.cfm
router-turning-machine-0093.jpg  router-turning-machine-0094.jpg  router-turning-machine-0095.jpg  router-turning-machine-0096.jpg  router-turning-machine-0097.jpg
router-turning-machine-0098.jpg  router-turning-machine-0099.jpg  router-turning-machine-0100.jpg  router-turning-machine-0101.jpg  router-turning-machine-0103.jpg
Workshop Projects
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 06:11 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
