| | #1 |
| Registered User | I am using a steel 1/16" bit with a 1/4" shank. I am using 3/4"MDF board to build a slot car track. The guide slots are .0625 deep and the rail pockets are.225 deep on the slot pins. Ive only gotten about 1 and 1/2 curves completed and I've broken 5 bits already. What am I doing wrong? Is there a secret to routing MDF board? |
| | #2 |
| Registered User Forum King | MDF is tough on bits. Creates a lot of heat. Don't route the full depth in one pass. Do half the depth first, then adjust for the final depth.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #3 |
| Registered User Supreme Forum King | Hi, welcome to the router forums. ![]() A 1/16" bit in MDF requires multiple passes as Mike suggested. I would take it in 3 maybe 4 passes. You're asking a lot from a bit specially in MDF.
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Bun I would suggest you don't chuck up any more 1/16" router bits,,LOL find a new way of doing the job like a SMALL saw blade for your Dremel Tool ... http://www.amazon.com/Dremel-670-01-...6926909&sr=8-2 I have one and it works very well for the job you are trying to do, the head will cam over to 30 deg. and you can set the depth of the blade very easy the blades don't last to long at high speed but if you have VS you crank it down so they don't burn up the blade/over heat the blade...but do buy some extra blades..MDF is hard on all cutting tools.. ![]() ========= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 03-30-2008 at 08:38 PM. | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 08:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 06:42 PM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
