Go Back   Router Forums > General Woodworking > Starting Off
Thread Tools Display Modes
Old 04-16-2008, 10:51 AM   #1
rharveyva
Jr. Member
rharveyva is on a distinguished road
Default Fix wood hole
I realize this is not about routing but I have a wood door with a lock and the screw keep coming out because there was a bigger screw there before. What product so you recommend to fill this hole i can drill and put a new screw in.
rharveyva is offline   Top - Reply with Quote
Old 04-16-2008, 11:04 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi rharveyva
Here's quick fix
A wooden match and some glue,,, coat the match and the hole with some glue, tap it into the hole, then let it set up for a bit then put the right screw in place..you can always drill a hole and put in a wooden dowel pin if the match trick didn't help..but I'm sure it should..
Bj
Old 04-17-2008, 12:12 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I prefer the second method BJ mentioned. Drill a hole for a 1/2" dowel and glue it in with a good water resistant glue like Titebond III. Use your latch or strike plate to mark the location for the new holes and carefully tighten the screws. Most often the proper screw is a #8 x 3/4" Phillips flat head. For the strike plate a #8 x 1-1/2" would give added strength.
Framing a small piece of wood lea6141 Table-mounted Routing 9 01-26-2008 09:29 PM
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 7 12-30-2007 06:18 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
