| | #1 |
| Registered User Jr. Member | I realize this is not about routing but I have a wood door with a lock and the screw keep coming out because there was a bigger screw there before. What product so you recommend to fill this hole i can drill and put a new screw in. |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi rharveyva Here's quick fix ![]() A wooden match and some glue,,, coat the match and the hole with some glue, tap it into the hole, then let it set up for a bit then put the right screw in place..you can always drill a hole and put in a wooden dowel pin if the match trick didn't help..but I'm sure it should.. ![]() ========== Quote:
__________________ Bj | |
| | #3 |
| Senior Moderator Supreme Forum King | I prefer the second method BJ mentioned. Drill a hole for a 1/2" dowel and glue it in with a good water resistant glue like Titebond III. Use your latch or strike plate to mark the location for the new holes and carefully tighten the screws. Most often the proper screw is a #8 x 3/4" Phillips flat head. For the strike plate a #8 x 1-1/2" would give added strength.
__________________ Mike |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 09:29 PM |
| Shelf pin hole jig - reviews and router solution | Greg_R | Jigs and Fixtures | 7 | 12-30-2007 06:18 PM |
| Which hole pattern should I get (plate for a Bosch 1617)? | Nickbee | Table-mounted Routing | 1 | 11-23-2007 06:49 PM |
| Drilling large hole over small hole or vice-versa | simplenik | Tools and Woodworking | 8 | 06-13-2007 07:57 PM |
| Routing a hole | Learning Herb | Tools and Woodworking | 11 | 03-20-2006 04:29 PM |
