| | #1 |
| Registered User New Member | Hello everyone, I need help with plunging grooves with my plunge router on top of a flat board which is approximately 6" wide X 12" long. I would like to make the indentations (grooves) about 2 inches by two inches wide, but only about 1/2" deep, with a 3/4" round bull nose router bit. I would like to make several of these in the board with only a half inch or so in between each finished 2 X 2 groove. I would like these to be oval in shape, not round. I was wondering if I need stop blocks or a pattern to do so or do people just draw them in and plunge away? I appreciate any help you can give me. Thanks! CAM |
| | #2 |
| Forum Contributer Supreme Forum King | HI Cam I'm not to sure if this is what you want but it's a simple template setup and using a brass guide to do the job.. You lost me when you said Oval.. ![]() ====
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 07-29-2008 at 05:34 PM. |
| | #3 |
| Registered User New Member | Yes, that is what I needed. Thanks! CAM |
| | #4 |
| Registered User New Member | Now I see why I lost you with the ovals because of the 2 inch by 2 inch indentations. That's not very oval is it? Your answer was perfect though. Now I know where to start. Thanks again, CAM |
| Tags |
| grooves, indentations, plunge routing, stop blocks |
| emergency stop modifications | kp91 | Show N' Tell | 10 | 02-07-2008 05:20 PM |
| Routing a decorative edge on the inside of a faceframe? | Woodworker 52 | Portable Routing | 2 | 01-29-2008 01:00 PM |
| White polyetheylene blocks | Poboy | Jigs and Fixtures | 16 | 08-08-2006 10:30 PM |
| Stop Posting! | Julie | Lobby | 7 | 10-03-2004 05:37 AM |
| Measuring blocks | DONALD | General Routing | 4 | 09-25-2004 10:44 AM |
