Go Back   Router Forums > General Woodworking > Starting Off
Starting Off If you're new to any power tool and/or woodworking technique, or you just have some general questions about starting a project, feel free to post your questions here!
Thread Tools Display Modes
Old 08-07-2008, 10:37 PM   #1
DennisF
DennisF's Avatar
DennisF is on a distinguished road
Default Craftsman router model #315.17492
Hi all,
I finally broke out an old router (looks like new) from 1987 and was working on some dados for a bookcase. I noticed that the base is off set by 1/16" on one side, is this normal?
If not, where might I buy a new base for this old router? I see Woodcraft has one that will fit Craftsman routers (315.275-000-100-110 and 315.175-070-040-050-060) do you think these will work?
Thanks for the help.....
DennisF is offline   Top - Reply with Quote
Old 08-08-2008, 12:14 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
The black plastic sub base plate should be centered on the bit. You can check by putting a 1/4" rod in your collet and measuring from the rod to the outer diameter of the sub base plate. If yours is not centered you are better off making a new plate because a replacement plate will use the same mounting holes. There is a post showing how to do this, a simple job.
Looking for manual/advice for Craftsman router model # 13517508 ljhammel General Routing 3 07-25-2008 06:47 PM
Looking for manual/advice for Craftsman router model # 13517508 ljhammel General Routing 0 07-24-2008 05:42 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
craftsman router model #26620 hshumsky Starting Off 2 01-11-2008 02:58 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
