Ooops - Router Forums
 13Likes
post #1 of 30 (permalink) Old 01-26-2017, 09:12 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default Ooops
1/2" cutter (was)
sunnybob is offline
post #2 of 30 (permalink) Old 01-26-2017, 10:53 AM
hawkeye10's Avatar
First Name: Don
Originally Posted by sunnybob View Post
1/2" cutter (was)
Alright Bob what have you done now??? Lokks like something I would do.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 30 (permalink) Old 01-26-2017, 11:20 AM
Did pieces go flying?
post #4 of 30 (permalink) Old 01-26-2017, 12:22 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I think I had a "steep learning curve".
Trouble was it was so steep I didnt learn what happened till afterwards.
It was in the router table, and I was running a square of beech (10" x 10" x 1") across it using a sliding mitre fence in a track.
Done that many times before and already ran this piece across once while trying to get a straight edge, but I think my "oops" moment was the beech was not sufficiently wedged against the fence.
The cutter bit in and the wood had nowhere to go except backwards and upwards. It threw the whole shebang off the table, wood and fence combined.
The BANG was so loud that my wife came out of the house and into the garage to see if I was still breathing.
I hadnt noticed the cutter damage untill i had put everything back and was just about to trim the next piece. I glanced at it and at first thought there was wood debris on it. Only when I tried to wipe it off that the true picture emerged.
All fingers present and correct. Lesson learned. Move along, nothing to see here.
Roy Drake and Herb Stoops like this.
sunnybob is offline
post #5 of 30 (permalink) Old 01-26-2017, 02:13 PM
vchiarelli's Avatar
First Name: Vince
Bob - I bet you were "shaken, not stirred". Glad you're OK.
Roy Drake likes this.
Either lead, follow, or get out of the way.
vchiarelli is offline
post #6 of 30 (permalink) Old 01-26-2017, 02:23 PM
Nickp's Avatar
First Name: Nick
Sorry to hear but glad you didn't get hurt...PHEW...
...but I have a question...was the wood between the fence and the bit...? Your description seemed to indicate it was... "the beech was not sufficiently wedged against the fence".
Which fence...the miter or table...?
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #7 of 30 (permalink) Old 01-26-2017, 03:36 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
The sliding mitre fence is in front of the bit, cutting direction correct (right to left). I'm not that green!
There is a small depth stop on the mitre fence, so the wood was pulled back to the mitre fence, and away from the cutter down to the stop.
But (hindsight is wonderful) The wood edge to be cut was too far away from the fence and i did not have sufficient force away from the cutter.
the wood edge was very angled, first thin slice only cut about an inch along the wood, but the second slice hit a grain twist and the cutter dug in. Game over.
Very annoying, that cutter was very sharp and working well. Shame about the operator.
sunnybob is offline
post #8 of 30 (permalink) Old 01-26-2017, 04:05 PM
Nickp's Avatar
First Name: Nick
My apologies...just covering bases...no "green" intended...again, glad you didn't get hurt...
Nick
Points to Ponder...
Nickp is offline
post #9 of 30 (permalink) Old 01-26-2017, 04:50 PM
Lucky, Bob...
Sydney, Australia
jw2170 is offline
post #10 of 30 (permalink) Old 01-26-2017, 05:56 PM
You are not alone. I did this to a very expensive spiral downcut bit. Not quite as spectacular, but got my attention.
Chris Hachet likes this.
Human Verification
Happy birthday Ross (old55) jw2170 Lobby 21 08-28-2016 10:56 AM
red neck dust collector bowdean Starting Off 24 11-14-2015 05:49 AM
Ooops & aw *(^(^%$# papawd Lobby 17 07-04-2012 11:20 PM
New Freud 1700 - Yay - Ooops -Oww - Baaww! jschaben General Routing 26 01-25-2010 04:57 PM
router bit layout dtaylor Table-mounted Routing 10 11-01-2009 11:49 AM
