| This is a discussion on Fastening Router Table To Cabinet within the Table-mounted Routing forums, part of the Routers category; Last weekend I decided to mount my router table on the unfinished cabinet I'm making. ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Last weekend I decided to mount my router table on the unfinished cabinet I'm making. I wanted to get the table out of my house and thought I would just install it temporially and remove it when I got around to finishing the cabinet. Several weeks ago I bought some double stick tape at HD that was labeled heavy duty. I thought it would be strong enough and I could remove the top when I got around to making and installing the doors on the cabinet. I put the tape on the top of the cabinet on all four sides. I thought I could place the table and then move it a little if I didn't get it straight. I placed the table on the cabinet as close to straight as I could. When I tried to move it back a little I couldn't budge it...........instant bond like contact cement. I tried to lift the table off by pulling but even when I picked the entire cabinet off the floor the top wouldn't budge. Tues. I was installing the fence on my Unisaw I backed into the cabinet and turned it over. It hit the garage floor very hard and I was sure the top would be broken because I have a very large PC 7518 router mounted in the top. Nothing broke and despite the hard hit the table was still stuck to the cabinet. So FWIW if you are looking for a permanent way of attaching your table this it. Just be sure it's where you want it before you set it down. | ||
| | #2 (permalink) | ||
| Retired Moderator ![]() |
Donald, is this double sided mounting tape or carpet tape? I could see the white mounting tape holding like that. As a rule I use the double sided carpet tape for jigs and holding pieces.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #3 (permalink) | ||
Mike this is double sided tape. It's red on the outside until you peel the film off. I didn't find it where the other tape display. If I remember right it was displayed with the velcro. I have tried some other double stick tape that was white but it didn't stick like this. I have to go to HD today or tomorrow so I'll look around for it and let you know where it's displayed. | ||
| | #4 (permalink) | ||
Mike the tape is in the paint dept. | ||
| | #5 (permalink) | ||
Is this a white foam tape? Ed | ||
| | #6 (permalink) | ||
If its at HD its carpet tape and is in the carpeting section. Its very good double sided tape. regards jerry | ||
| | #7 (permalink) | ||
hmmmm..... You may have given me the answer to mounting my top to my cabinet when I get it finished. I was curious about how I would mount it, but now I may know I wonder how it will hold to the slick lamination of the rocklet table?
__________________ a/k/a "Grumpa" | ||
| | #8 (permalink) | |||
Before you use it to hold anything heavy please test it using a small strip. When I tried a small piece off the roll I bought yesterday it didn't seem as strong as the first roll. The only thing I know for sure is that the tape I used had a removable red film on one side and the other side was sticky and it's holding my router table to the cabinet. I hadn't finished the cabinet and wasn't looking for a permanent attachment. | |||
| CMT Industrio Router Table System (orange cabinet) | Ladd | Table-mounted Routing | 51 | 03-08-2010 11:29 AM |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 01:08 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 06:42 PM |
| Router table upgrade | kp91 | Show N' Tell | 4 | 10-24-2005 02:59 PM |
