Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Router Base Plate Question
This is a discussion on Router Base Plate Question within the Table-mounted Routing forums, part of the Routers category; I have been making trivets for Christmas using the design by Incra with appropriate Incra ...
Old 12-24-2008, 10:15 AM   #1 (permalink)
dabeeler is on a distinguished road
Default Router Base Plate Question
Report Post Report This Post!
I have been making trivets for Christmas using the design by Incra with appropriate Incra guides. The problem I have noticed is that part of the cuts are slightly deeper than others. The router table is a Bosch table with the Bosh phenolic ( I think) base plate to which I have a Frued plunge router mounted with the Router Razier kit. The trivet being routed it 6" X 6" with the cut being stopped 11/16" from each edge. It is the last couple of cuts with the Incra fence furtherest away from the bit that has the problem. Is it most likely that I am getting some base plate deflection from the weight of my hand on top of the trivet when my hand is nearest or over the bit? I am thinking that if it were the throat insert deflecting then the problem would be at the spot that my hand passed over the bit and not the full length of the cut. The fence is square to the table top and the base insert is level with the table top. Any other ideas as to the cause? What would be the best way to isolate the cause?
Thanks,
David
dabeeler is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 12-24-2008, 11:54 AM   #2 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
Hi David
"the weight of my hand on top of the trivet when my hand is nearest or over the bit?"
That maybe it,, by the way not the best way to do it bits sometimes like to come free and come up a bit to high and cut a slot in your hand.
Try this,, make a push block, that sits on top of the trivets with a handle dead center of the push block with a small block on the end of the push block to help push it over the bit...
something like the one below
Thanks,
David
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 12-24-2008, 12:10 PM   #3 (permalink)
I will give that a try, thanks.
dabeeler is offline
Old 12-24-2008, 01:21 PM   #4 (permalink)
Hamlin's Avatar
First Name: Ken
Hamlin has a spectacular aura about
Hi,
Bj is right on. You need a push block to use. Never let your hands or fingers get close to a spinning bit.
You may wish to take a look at the OP spacer fences. They make trivets quite easily and safe.
Ken
"A VETERAN"
Hamlin is offline
New Router my way reible General Routing 20 11-30-2011 11:18 AM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 07:35 PM
question about router plate mwm500 General Routing 5 09-20-2006 05:58 PM
base plate for King router Tony Tools and Woodworking 0 01-26-2005 08:04 AM
