| | #1 |
| Registered User Member | Got a little problem. I'm making bandsaw boxes and the drawers all have curve outlines, some are cresent shaped. I'd like to use a table mounted piloted round over bit to save some sanding on the edges of the drawers. The problem is that the backs, and fronts also on some boxes, are 1/4" thick. When I set the bit height for the round over I want, the bearing is above the material. I'd like to isolate the bearing but the concave sides of the drawers prevent this. I'm sure I'm missing something obvious. Thanks for any advise. Ken
__________________ There is no shame in saying 'I don't know'. |
| | #2 |
| Forum Moderator Supreme Forum King | Maybe you could make a template to thicken it up and use that for a bearing guide just a suggestion and it might work. Or double the pieces up with 2 sided tape and run them through. ![]() |
| | #3 |
| The Router Guys Forum King | What bit radius? Can we change this to a smaller one or can we lower the round over router bit until the bearing works. We are just rounding the pieces over, right?. Another way is to use the chamfer bit and lower the bit as needed. Just a few thoughts,
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #4 | |
| Registered User Member | Quote:
Here is an image of a completed box, maybe this will help explain: ![]() The front is 1/2" thick so it's not a problem, but the back is 1/4". Maybe, thinking about it, I should just make the back a little thicker and give up a little of the drawer cavity. The drawer is cut from a solid block, the front and back are sliced off, the drawer cavity is cut out, then the back and front are glued back on. Thanks again, ken BTW, BobandRick, thanks so much for helping me and others with your show.
__________________ There is no shame in saying 'I don't know'. | |
| | #5 |
| Registered User Dedicated Member | Great looking work there Ken: Maybe I can make a suggestion to the admins. about potentially have a competition involving (non-pro) woodsman that can show off their finished projects and have them viewed and judged.Just a thought! Dave. |
| | #6 |
| The Router Guys Forum King | Great project Ken!
| | #7 |
| Registered User Forum Fanatic | Beautiful Job Ken. |
| | #8 |
| Registered User Dedicated Member | Ken,I used a dremel tool with a small barrel sander to round over the edges on this box.It seemed to work pretty good
__________________ JH |
| | #9 |
| Registered User Member | Thanks for the advise and nice comments. I may try the Dremel option as John suggested.. ken
| small pieces | fishlore | Table-mounted Routing | 58 | 11-21-2007 07:23 PM |
| Groove in edge of curved piece | imrichb | Router Bits - Types and Usage | 5 | 07-06-2007 02:03 PM |
| Making Curved Moulding | cabinetman | Project Plans and How To | 8 | 04-25-2007 07:42 AM |
| Half-round concave cut on a curved 2x8 semicircle | Roberto1 | Tools and Woodworking | 6 | 09-13-2006 06:19 PM |
| jig for turning round legs. | heisnerd | Jigs and Fixtures | 1 | 10-05-2004 03:04 PM |
