| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | I was watching episode 1005 where Bob was cutting mortise and tenon joints in the face frame for the bookcase part of the oak secretary. He used what looked like a dual slot cutting bit to form the tenon, I had never seen that before. The guy at my favorite tool shop had never heard of such a thing either. Does anyone know a manufacturer for that bit. I have checked with a couple router bit manufacturers and I did not see any bits that looked similar. Any help would be appreciated. John, TheVogon |
| | #2 |
| The Router Guys Forum King | The router bit that Bob used was an Oak-Park.com router bit. But is just two wing cutters mounted on 1/2" arbor with a 1/4" spacer...should be able to find this anywhere.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 | |
| Registered User | Quote:
![]() Good Luck John
__________________ Living in the Sportsman's Paradise WWW.Craftsman-Furniture.com Last edited by Mark; 09-21-2004 at 12:01 PM. | |
| | #4 |
| Registered User New Member | I found the tongue and groove set made by Freud, and the slot cutting bits made by almost all the bit manufacturers. However, I noticed that both of these setups will not cut tenons longer than 7/8 to 1". When I was making the baby crib for my new daughter, the plans called for some tenons as long as 1 3/8". I have also read some plans using longer tenons especially on through tenons. Is there a way to cut these with the router? I thought about using a dado or mortising bit to clean off both faces, but the setup is a little more crucial than with the slot cutter. Any ideas? John |
| Mortise & Tenon Jig for the Plunge Router | bobj3 | Jigs and Fixtures | 39 | 05-22-2008 09:57 AM |
| How to do Mortise and Tenon? | JDługosz | Jigs and Fixtures | 26 | 10-21-2007 02:17 PM |
| Mortise & tenon vs. biscuits | berry | Starting Off | 4 | 07-25-2006 04:15 PM |
| Mortise & Tenon System Router questions | kenadian | Table-mounted Routing | 2 | 11-17-2005 04:22 PM |
| mortise and tenon system | kellyp | Jigs and Fixtures | 1 | 02-15-2005 04:36 PM |
