Rate This Thread - Problem with my Hitachi M12V.
Thread Tools Display Modes
Old 08-06-2005, 10:16 AM   #1
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Visteonguy is on a distinguished road
Default Problem with my Hitachi M12V
I have the M-12V mounted in a router table resembling the one used on the show, "Router Workshop". It has worked fine up till last night when it started to shut down after running a bit. I thought it was maybe shuting down because of an over heating condition, because it seems to be suceptable to accumulating saw dust inside the housing from being hung upside down in the router table. I have noticed that it does seem to fill up in the spaces that the post use when it is plunged to raise the router bits, and after a while you need to clear that saw dust to plung the router to the full extent possible.
I removed it and blew it out as best as I could, but there was not a lot of saw dust that came from the inside of the housing. I reinstalled it and it worked for a few minutes and then shut down again,,, I checked the brushes and they seemed to be fine,,,, about a half inch or a bit more of brush material remained, but I never removed them before so I am not sure how much material is on a new set of brushes. I am running red oak boards of about 22 and 30 inches and making molding for a room I am rebuilding, I do not feel I have "overused" this router for the period that I have owned it, so I do not feel it is worn out. I let it set over night and started this morning and it shut down after running only 3 boards so I know its not an over heating problem.
Has anyone else experienced this problem with their M-12V or know how to contact Hitachi to remedy this problem ?
Visteonguy is offline   Top - Reply with Quote
Old 08-06-2005, 05:38 PM   #2
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Let me be the first to welcome you to forum. Sorry I can't help you out with your problem but I'm sure someone will. There is a lot of members here that own that model router.
Glenmore is offline   Top - Reply with Quote
Old 08-06-2005, 07:48 PM   #3
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
You can contact Hitachi at http://www.hitachipowertools.com/cust_service.php or by phone at 1-800-706-7337.
Hope tha helps.
Please let us know what they say, as again, a number of users here have the same router (myself being one of them).
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 08-06-2005, 10:43 PM   #4
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Thanks Stan for the fast reply,, I will email then as soon as I am done sending this email to the forum, I will let you know the results. The router has gobs of power and has up till this point, worked more or less, flawlessly,, but its not shinning too brightly right now. Its only about 3 years old and I have not really worked it to death,,, but some times things like this happen,,,always seems like it happens when its needed most.
Old 08-07-2005, 01:41 AM   #5
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Welcome aboard Visteonguy. I haven't had this problem with my M12V, but I have had occation to talk to the folks at Hatachi about my router somr time back. I can tell you that they were really helpful and courtious to me.
I have had simular problems with drills and grinders though. Almost all of them had brushes that were sticking in the brush holder and/or a dirty commintator. A good cleaning fixed all of them except 1 or 2. If you do tackle this cleaning job, get a good electrical contact cleaner to clean it, should be available from any electrical supply. Good luck.....Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Old 08-07-2005, 02:50 AM   #6
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You said there was a lot of saw dust that came from the inside of the housing... and I believe this is the cause of your overheating/thermal shutdown. You may need to take this unit apart to get ALL the dust and debris out of it. It would not surprize me that your brushes were ready to be changed. The easiest way to be sure is to look at a new pair and see how much is worn away. It is also possible that you have one or more bearings close to failure, and that is a sure cause of over heating. This type of troubleshooting and maintenance is best done by a professional, so unless you are 100% sure of yourself take it to the service center.
Old 08-07-2005, 12:26 PM   #7
Visteonguy
Forum Fanatic
Visteonguy's Avatar
No, Mike,,, I thought I would see a lot of sawdust come out of the housing, but in fact, seen very little come out at all. I have found out that the new brushes are 17 mm long when new, and mine are now at 16.04 mm, so there should be lots of life left in them. The router was bought new in 2001 and I have used it some, but really not an excessive amount... so I find it hard to believe that the bearings are going south already,,, if they are, then that does not say a lot for the durablility or reliability of Hitachi tools.. I am thinking there is a problem in the electrical end of the tool,,,, I see there is a "control circut modual" that will cost me $104.42 or the switch that will cost a more livable $20,,, and new brushes that pretty much use up a 5 dollar bill...
Anyway, I have emailed Hitachi and am awaiting their reply. I hope they can be as helpful to me as they were to Chuck... I will let you know if after seeing their reply,,, I am still a happy Hitachi owner...
Terry
Old 08-08-2005, 01:05 AM   #8
reible
Supreme Forum King
reible's Avatar
Hi,
One think that has come up before with problems like you mentioned has to do with the way your router gets its AC power.
As you no doubt know this router has a heavy current draw and as such needs to have good wiring to it. A voltage drop in a dropcord, the lack of heavy enough wiring in the shop... running a series of other tools at the same time like dust collectors, compressors, air conditioners or other items can lower the voltage to the router. If the outlet you plug into has overheated sometime in the past the outlet may even be at fault. Some times even the power companies are at fault...... especially during summer heat waves you end up being in either a brown out or nearly there.
To see if it really not the router you will need to plug into some other outlet that has nothing else running on it and see if that solves the problem. If another outlet is not close at hand then get a heavy duty 12 ga. drop cord and use that for the test. The test being doing the same router operations you have been doing. If the router stays routing then you will have to find the cause of the voltage drop in your system.
If on the other hand the router is still not working right it could be the expensive speed control or other problems. But if the electical in the shop is bad it could cause the fault you have and will just wreck the next one you get so either check it out or have an expert in to do it.
I hope this was not to confusing.......
The forum also has a search function and if you look at hitachi you will find links to posts like this one:
www.routerforums.com/showthread.php?t=312
Good luck,
Ed
Old 08-08-2005, 10:39 AM   #9
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Thanks Ed for the ideas,,, I have been using the router in its table since I bought it back in 2001 and its not shown any problems like this before. I understand what you are talking about with the voltage drop.
The job I am running on it now, is making moldings, and they are only 30 inches and 22 inches long, and not quite 1 inch thick. If I go and start now after its been sitting all night, I can run maybe 7 - 10 molding before it shuts down,,,, and then I let it set for maybe 15 minutes and start again,,, and can get only about 2 to 4 cuts and it shuts down again. Sounds to me like an over heating problem but you put your hand on the router and its hardly warm at all, so that stumps me. I find it hard to believe that routing just a couple of 22 inch cuts will over heat the machine. I feel no play, nore feel any grinding sensations while you turn the shaft by hand, to indicate bearings on their way out and with the time I have acutally used this machine,,, I find it hard to believe that the bearings are wearing out already. When I started to make these moldings,,, and I need a lot of em.. I ran maybe 75 of the shorter ones of 22 inches and about 70 of the longer 30 inch ones with out a problem, and I ran them as fast as I could,,, one after another and all of a sudden,, it started to shut down.. And I have had the problem ever since. Nothing else has changed as far as the power is concerned. I built the house myself and wired it myself so I know the wiring is good, It was done with 12/3 to all the plugs and there was not very many plugs per circut. Not much else was running in the shop when the problem developed so I do not feel like it was starving for current.
Any way I am waiting for Hitachi to reply to my emial so maybe they can enlighten me. It just ticks me off that this project has to come to a screaching halt while I deal with this router
But I appreciate your ideas and if you think of anything else... let me know, Thanks again.
Terry
Old 08-10-2005, 10:54 PM   #10
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Hitachi has replied to my email... seems like they think that the problem lies in a falty speed control circut. I found a site on the net that I can buy this part for just over a hundred bucks,,,, and Hitachi said it lists for $88 from another supplier, but when ya add shipping ,,, it pretty much squeezes a C-note to death either way,,,
Seems pretty stupid to put almost as much into repairing a tool as it would to replace it. This router was not used anymore then the average woodworker would use it, I guess I am saying that it was surely not worked to death in the 4 years or so that I owned it,,,, I have 7 routers as of last count so the routing duties were shared by all of them depending on what job had to be done.
Now I see that this router, as most of Hitachi's tools, now carry a 5 year warranty,,, however,,,, I had the bad luck to purchase mine before they upped the number of years that were covered under warranty,,, mine only had 1 year.
I just checked on EBAY and seen 2 brand new factory reconditioned M-12V's go for $132 that had the 5 year warranty to boot.
I will replace the router,,,, but I have to base my decision on what brand to buy now, on how that M-12V has preformed,,, and I have to tell you that I have a bad taste on my mouth from this experience,,, so I guess I am done with Hitachi tools from now on,, Some times parts fail,,, but when it happens to you and you find out that it will cost ya almost the whole price of a new one to fix it,,,, It gives ya an attitude.
So anyway,,, if your M-12V starts acting up like it has an over heating problem,,,, Ya have my sympathies,,,
1/4" Collet for Hitachi M12V RzzB General Routing 37 05-27-2008 08:11 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 09:34 PM
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 3 06-03-2006 10:42 AM
Hitachi M12V issue Warren White General Routing 4 03-23-2005 10:03 PM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
