Help
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Plate screw-up help
This is a discussion on Plate screw-up help within the Table-mounted Routing forums, part of the Routers category; Dangkit all - I just tapped a 1/2" hole into a Rockler aluminum plate for ...
LinkBack (1) Thread Tools Display Modes
Old 04-22-2009, 01:10 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Rooky is on a distinguished road
Default Plate screw-up help
Report Post Report This Post!
Dangkit all - I just tapped a 1/2" hole into a Rockler aluminum plate for a RouterRaizer ... well, I tried to. I had the beast clamped to the drill press table, started the hole and then the buzzard bit "walked" to a hole right next to this one, the hole that's there for a fulcrum pin? Anyway - made a major mess of my plate. I'm so PO'd ..... grrrrrrrrrr.
So I got a mess - if I continue on and finish it where it has to be it will be about a full 1" hole. In a metal plate. That's not okay ...... so my choices are to fill it in somehow as is, expand it to be correct for the Raizer opening or get a new stinkin' plate. Which of course is a 9 x 13, which is the discontinued one from Rockler. Every other plate out there is smaller and nope - I will not redo the top. No way no how. It's summer ime and not repair time.
So what the dickens do I do to fill in that hole?
Rooky is offline
Old 04-22-2009, 01:29 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Rooky
Just use it the way it is now it's not a big deal...you can fill it and start over but it will cost more than the plate..and it's good chance it will warp the plate when you fill the hole..
If you want and try and repair it,, tap the hole out to take on a ALUM. bolt,screw it in the hole/cut it off 1st. and state it in place then redrill the hole..
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
How to Remove and Reinstall a Drill Press Chuck
See all 48 videos, Great tips.
http://www.youtube.com/watch?v=KbI_7...=31&playnext=3
HOW TO Inset a Router Base Plate
http://www.popularwoodworking.com/ar...e_plate_video/
Wood Working Videos, many great ones.
http://web.me.com/deceiver6/Deceiver/wwvideos.html
Router Tables
Router Tables Made Easy, with this video.
http://www.sommerfeldtools.com/Route...ductinfo/DVD3/
http://www.youtube.com/watch?v=sFW5gBYwt4M
http://www.youtube.com/watch?v=QjW5H...eature=channel
Old 04-22-2009, 02:29 PM   #3 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
They make JB weld for aluminum. That may fill it in.
AxlMyk is offline
Sponsored Advertisements. Register to disable this advertisement.
Old 04-22-2009, 02:54 PM   #4 (permalink)
It freaks me out to think what might happen when I finish tapping that hole gone bad - I suppose I could live with the hole as is but then it kills the use of the Raizer and I'm back to adjusting from underneath since I can't get the wrench in w/o enlarging to where it should have been when I started to drill.
I even had punched in a nice ol' starting spot. No sense fretting that - damage done.
I guess it enlarge the stinger --- that JB weld sounds interesting if it's to nasty looking.
Why do I sense I'll be popping another $70 for a plate before they 100% gone off the Rockler earth? Money. Always comes down to money
Rooky is offline
Old 04-22-2009, 03:32 PM   #5 (permalink)
First Name: George
George II is on a distinguished road
Duro, I Think, makes a liquid Alum. filler I know of someone that used it to repair a crack in a alum. engine block....Just fill it sand it smooth, zinc chromate it, paint it and rock on...That $70.00 can but a load of beer, wood, woodworking stuff, and things..
George
George II is offline
10% OFF at Rockler.com!
Old 04-23-2009, 09:49 AM   #6 (permalink)
CharleyL is on a distinguished road
Next time, when you are going to drill a big hole, start with a small bit and then use bits of increasing size until you reach the diameter that you want. A small bit will stay in the center punched mark better. A center drill would be an even better choice to start with as they are designed to do this without walking out of the center punch mark.
CharleyL
CharleyL is offline
Old 04-23-2009, 01:37 PM   #7 (permalink)
First Name: Lance
westend is on a distinguished road
Oooooh, sorry to hear about that. You are not alone in machinery assisted miscues .
JB Weld will work but not guaranteed to machine correctly. I've actually used it for aluminum prop repair and it has held up.
Mtka. Rockler did have a box of discontinued insert plates back in the clearance section. Last time I was in there (about two weeks), there were about 20-30 of them. They were going for $25, IIRC. I needed the 9 x 11 for a Bosch and called around to the local Rocklers until I found one in Burnsville. $25 is what I paid. Good luck with the workaround.
Sawdust is not dirt
westend is offline
Shop now at Tool King!
Old 04-23-2009, 04:21 PM   #8 (permalink)
First Name: Larry
ldykeman is on a distinguished road
There are a few products out there that allow you to weld aluminum with a propane torch, so there is a relatively lower head on the aluminum. DuraFix and Alumaweld are two. I haven't used them personally, but maybe someone else here has.
Larry
ldykeman is offline
Old 04-23-2009, 04:22 PM   #9 (permalink)
First Name: Larry
whoops, "heat", not "head"
ldykeman is offline
Shop now at Rockler.com!
Old 04-24-2009, 03:35 AM   #10 (permalink)
First Name: Murray
Lemuzz is on a distinguished road
Send a message via Skype™ to Lemuzz
Larry
If you use heat enough to get the parent metal to weld, it is at melting point and using propane to achieve this you will end up with a molten mess.
TIG welding is the only way to go. It wont be a cheap repair
"There's no such thing as a stupid question but they are the easiest to answer."
Lemuzz is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/table-mounted-routing/13951-plate-screw-up-help.html
Posted By For Type Date
Aluminum Welding Industry Resources This thread Refback 04-22-2010 01:59 PM
Marvel 40 Router Plate cbsjoez1935 General Routing 2 04-06-2009 05:23 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Craftsman scroll saw part? Birch Wood Scrolling 6 11-17-2007 02:47 PM
How To Destroy Screw Heads cabinetman Lobby 4 06-09-2007 06:03 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
