| This is a discussion on Box Bottom within the Table-mounted Routing forums, part of the Routers category; G'Day All Can someone please advise how best to make the grooves in the sides ... |
| | #1 (permalink) | ||
| Registered User ![]() |
G'Day All Can someone please advise how best to make the grooves in the sides of the box for the bottom. If I use a slot cutter bit I get round corners inside. Go easy on me I'm new to using my router. Any help appreciated. Cheers Bernie | ||
| | #2 (permalink) | ||
| Forum Contributor ![]() |
It's called a stopped dado. I do them by setting up stop blocks against the fence, or by putting marks on it. You start the router and push the wood down onto the spinning bit to start it. When you gert to the end, turn the router off, and then lift the stock off when the bit stops.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| | #3 (permalink) | ||
G'Day Mike Thanks for that, will give it a go and let you know how I go. Cheers Bernie | ||
| | #4 (permalink) | ||
Not sure I understand the question. If you use a slot cutter on each piece before assembly, and cut all the way through each piece, how are you ending up with round corners? Any slot stopped before the end of the cut is going to result in a rounded corner because the cutting tool whether it's a dado or slot cutter is round. In that case you'll need to square it off with a chisel. | ||
| | #5 (permalink) | ||
G'Day Joe Thanks, see your point. Have tried stopped dado as Mike mentioned, and seems to work, so I won't push my luck. Cheers Bernie | ||
| | #6 (permalink) | ||
That's what I use. Box-Slotting Bits - Lee Valley Tools It's easy to round the corners for the bottom. | ||
| | #7 (permalink) | ||
Hi Bernie It's hard to do with a slot cutter.the size of the bit is just to big it diam.the norm.pull the slot cutter out and chuck up a strait bit and then you get the job done with a start and stop blocks. ![]() ==========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #8 (permalink) | ||
| Registered User ![]() Join Date: Feb 2009 Location: Central North Carolina First Name: Charles Posts: 28 ![]() |
Lee Valley makes 2 small diameter bits for slotting boxes for the bottoms on a router table. These won't elminate the round corners, but will make them much smaller and easier to work with, and are ideal for making small boxes. I too like to clamp together the sides of boxes and slot them for the bottoms on the router table. I find it much easier and safer than making stopped dados on smaller pieces. CharleyL | ||
| | #9 (permalink) | ||
Ok, help me out here, are we talking about cutting the slot for the bottom after the box is assembled? Why? Are you talking about rabetting the bottom of the sides? to accept a flush bottom? | ||
| | #10 (permalink) | ||
| Retired Moderator ![]() |
Hi, Why are you using a slot cutter for cutting the groove for the bottoms? Doesn't matter if you're using a slot cutter or the one's from Lee Valley, it's still going to leave a rounded corner. To prevent this, you need to use either a straight or spiral bit and stopped dado's. Otherwise, you'll need to round the corners on the bottom piece. I guess I must be missing something here.
__________________ Ken ***Please fill in your profile, at least your location. As this will help us help you better.*** "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | ||
| A tiny project with lots of pictures | harrysin | Project Plans and How To | 52 | 12-17-2009 10:55 AM |
| Incra Ultra How-To (Box Joints + Other Stuff) | Nickbee | Show N' Tell | 17 | 06-22-2009 12:42 PM |
| Table top display cse. | derek willis | Show N' Tell | 3 | 03-05-2009 09:12 AM |
| Flush Trim Bit Top Bearing vs. Bottom Bearing | steveD | Router Bits - Types and Usage | 14 | 12-22-2008 01:36 PM |
| Trimming mitered hardwood edging | Drew Eckhardt | General Routing | 5 | 10-11-2008 07:59 PM |
