Help
Shop made router lift
This is a discussion on Shop made router lift within the Table-mounted Routing forums, part of the Routers category; There have been several threads about router lifts lately, and I didn't want to high-jack ...
Old 05-27-2009, 09:55 AM   #1 (permalink)
Noob's Avatar
First Name: Paulo
Noob is on a distinguished road
Default Shop made router lift
Report Post Report This Post!
There have been several threads about router lifts lately, and I didn't want to high-jack someone else's thread so I thought I would start a new one. Instead of spending big bucks on a lift, it is possible to make your own, and the good thing is someone else already did the dirty work of figuring out the dimensions and parts to needed to build one.
One of them is from Popular Woodworking and is pretty straight forward.
The plans can be found here (p. 19 of the PDF) Router table with router lift LINK
Another one that looks good is the one from American Woodworker. Everything but the bushings and steel shaft can be bought from Home Depot and Rockler.
The bushings can be bought at Amazon FF-1011-1 Oilite Sintered Bronze Flanged Sleeve Bearing 3/4" ID
The 18" steel shaft is from Metal Supermarkets LINK but there site kind of bites. Go to it and pick: Steel Cold Rolled > Round > 1045 > GROUND SHAFTING 1045 .750
There are steel shafts on Ebay and Oilite bronze bushings also. You can go to the American Woodworker site for more details on building this lift.
File Type: jpg American Woodworker router lift plan.jpg (340.6 KB, 172 views)
Noob is offline
Old 05-27-2009, 05:12 PM   #2 (permalink)
levon's Avatar
First Name: levon
levon is on a distinguished road
hi paulo,
im sure this works great, but it sure seems easier to buy a router for 100 bucks than to pay for and build this cumbersome looking lift. i want to be able to have accessibility to the router and anything that makes it easier to adjust and change bits in is what i want, after working with the router table awhile, you may agree with me. that is just my humble opinion.
levon
levon is offline
Old 05-27-2009, 05:43 PM   #3 (permalink)
Noob's Avatar
First Name: Paulo
I can't argue with that. You would probably have to have a dedicated router for the router table to use one of these, and a flip-top would make changing the bits a breeze.
I just thought I would throw this out there because in the same manner that some would rather make a router table top and router table than make them, someone may want to make a lift instead. Also there is the aspect of not being able to afford a router lift so if you really want one you could make one.
I've bounced around with a few ideas for a lift, but since I only have one router, I will probably just attach it to a mounting plate and be done with it. I have an old Porter Cable router and instead of spending $170 to $270 for a Rockler/Rousseau/Jointech/Woodpecker router lift, I can simply reach under the table and give the PC a twist to raise or lower it.
Noob is offline
Old 05-27-2009, 06:20 PM   #4 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
HI Noob
If you want a lift for your router take a hard look at the router raizer kit,it's way over price for some washers and some rod coupling nut,tubing and some threaded rod,,the kit comes with many items that are not used... the kit has many items to fit many routers...but they charge you for them.. if I recall I have a bag of 20 to 25 parts left over...
Router Raizer
http://www.routertechnologies.com/pc693.htm
http://www.routertechnologies.com/ty...ase_with_9.htm
below you will see snapshot of the lift and the parts that is needed to do the job..
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 05-27-2009, 07:35 PM   #5 (permalink)
Noob's Avatar
First Name: Paulo
HI Noob
Router Raizer
New Page 1
Type 2 base with 9
Thanks Bobj for that link. It jogged my memory and remember seeing a router crank in a book called "Router Magic" by Bill Hylton. That is another route that's worth looking into. Router Magic book LINK
Noob is offline
Old 05-27-2009, 08:01 PM   #6 (permalink)
bobj3's Avatar
Hi Paulo
Yep that's a good one but the only down fall on that one it's made to be use on under side of the router in the cabinet and not for the above table adjustment ..
I have Bill Hylton book and read it all the time
Part Finder
Bob J.
Old 05-27-2009, 08:46 PM   #7 (permalink)
Noob's Avatar
First Name: Paulo
Hi Paulo
That reminds me, I need to quit reading books and articles on routers and actually go out and use it.
Noob is offline
Old 01-19-2010, 01:02 AM   #8 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
"That reminds me, I need to quit reading books and articles on routers and actually go out and use it."
I concur with that Paulo, once safety is understood, only use, use and more use will turn a beginner into a Routologist, isn't that true Jim?
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Motorized Router Lift - wiring video johnwnixon Table-mounted Routing 8 04-01-2009 02:38 PM
Router lift DougO General Routing 3 01-14-2008 01:13 AM
Jessem Router lift Versa Incra Precision Router Lift ragman Table-mounted Routing 3 04-01-2006 07:05 PM
