Help
freud ft3000vce
This is a discussion on freud ft3000vce within the Table-mounted Routing forums, part of the Routers category; anybody using one of these in a table? I'm leaning towards one, just looking for ...
Old 05-29-2009, 05:34 PM   #1 (permalink)
bwarner is on a distinguished road
Default freud ft3000vce
Report Post Report This Post!
anybody using one of these in a table? I'm leaning towards one, just looking for experienced opinions ?
thanks, bw
bwarner is offline
Old 05-29-2009, 06:41 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
HI bw
I don't have the 3000 but I have one or two of the 2000 ser.in the router tables, they are great,,I just couldn't see putting out that much for a above table adjustment device.. plus I can change the bits from the top of the table with the 2000 ser..
Amazon.com: Freud FT2200EP 3-1/4-Horsepower Variable Speed Plunge Router with Free Edge Guide: Home Improvement
Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router (Reconditioned)
Freud FT2200E 3-1/4 HP Router with Cruise Control (Reconditioned)
Freud FT2200EP 3-1/4 HP Router with Cruise Control and Edge Guide
http://www.routertechnologies.com/in...eud%20pack.PDF
http://www.routertechnologies.com/index.html
thanks, bw
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
bobj3 is online now
Old 05-29-2009, 07:08 PM   #3 (permalink)
so the only difference is the above table adjustment, 3000 vs. 2200 ?
bw
bwarner is offline
Old 05-29-2009, 07:21 PM   #4 (permalink)
bobj3's Avatar
Hi bw
Well yes and no ,,the 3000 will lift the bit higher so you can use the standard fac. wrench with it but for 14.oo or one of yours that you may have on hand you can use a off set one , and to make your own adjustment crank is duck soup..see the other post to see what parts are needed to do so..
But I will say you don't need the crank lift because is so easy to lift the router in to place with the fac.knob that comes with all of them,,,most of the time you only need to move the router up and down by 1" or less the norm..plus you can still use it as a hand plunge router out the table...
bw
Part Finder
Bob J.
bobj3 is online now
Old 05-30-2009, 03:06 AM   #5 (permalink)
derek willis's Avatar
First Name: Derek
derek willis will become famous soon enough
I have been using the 2200 Freud router for about 16 years now and find it absolutely perfect for table use, ( replaced it a few years ago after I made a blunder and damaged the first one).
Derek
derek willis is offline
Milwaukee 5625-20 & Freud FT3000VCE Info John_B General Routing 5 03-30-2009 12:25 PM
Public Thank You to Freud and Charles Gerard_sr General Routing 1 01-17-2009 07:07 AM
Freud Router stjimm Introductions 1 01-03-2009 11:04 AM
Red Freud., Black Freud "industrial" Drew Eckhardt Router Bits - Types and Usage 5 09-09-2008 03:56 PM
Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router Bridge Introductions 6 07-23-2008 03:17 PM
