Help
Freud raised panel bit????
This is a discussion on Freud raised panel bit???? within the Table-mounted Routing forums, part of the Routers category; I just received a Rockler order today. One of the items was a Freud Quadra-Cut ...
Old 06-05-2009, 07:51 PM   #1 (permalink)
First Name: Harry
Old_Chipper is on a distinguished road
Default Freud raised panel bit????
Report Post Report This Post!
I just received a Rockler order today. One of the items was a Freud Quadra-Cut Ogee Raised Panel Bit with Backcutter. Item #38231. As I started to install it, I noticed it had no bearing between profile and back cutter. I have about 15 of these type of cutters, lots of different brands, they all have the bearing. This is my first Freud of this type.
If any of you have used this set, does it have a bearing or did you have to install one. Or use it as is, seems to me it will burn, when I cut the arches. I'm doing the tombstone arched doors, in red oak! The straight cuts will be no problem as I can use the fence.
but I don't want to ruin a $100.00 bit!!!
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
Old 06-05-2009, 07:55 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
HI Harry
That's the way they come...no bearing
http://www.rockler.com/gallery.cfm?O...Select=Details
http://www.rockler.com/product.cfm?p...38231&pn=38231
It will put some red paint on the panel edge and some burn marks but it's no big deal because you can't see it but take care of the heat on the bit,it will get hotter than the norm with a bearing.
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-08-2009, 04:17 AM   #3 (permalink)
First Name: Harry
thanks,
I been using it. It does a nice job, great finish but I STILL think it should have a bearing. I would like it better if it were 1/2" smaller in dia. Vaccum system can't suck the chips away fast enough. Makes a mess compared to the ones I been using! But that's why we have brooms, right?
Thanks again<
Harry, TX
Freud Diablo Raised panel set. derek willis Table-mounted Routing 14 01-24-2009 06:00 AM
Freud Diablo Raised panel set. derek willis Table-mounted Routing 0 01-22-2009 10:17 AM
Freud Diablo Raised panel set. derek willis Table-mounted Routing 0 01-22-2009 09:55 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
