| This is a discussion on Springs In or Springs Out? within the Table-mounted Routing forums, part of the Routers category; Looking for the collective opinion on this. When using a plunge router that is dedicated ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Looking for the collective opinion on this. When using a plunge router that is dedicated to a table, do you remove the springs? | ||
| | #2 (permalink) | ||
| Registered User ![]() Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 2,443 ![]() ![]() ![]() |
I didn't.
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. | ||
| | #3 (permalink) | ||
| Forum Contributor ![]() |
Hi Tom That's 50/50 thing for most,,some router don't need the springs remove,you are moving the router up or down by a 1" or so most of the time.. But some of the big routers need the springs removed because they are 15 lbs.plus...and a hard to adjust if the springs are in,, but I must say once you take the out that's it the norm...it now a router for table only.. I would suggest you don't take them out..but if you have more than one router go for it ![]() ========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #4 (permalink) | ||
| Retired Moderator ![]() |
Tom, It depends on the router. Some do, some don't.
__________________ Ken ***Please fill in your profile, at least your location. As this will help us help you better.*** "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | ||
| | #5 (permalink) | ||
I personally remove the springs but I would suggest that you try both ways and settle for whichever feels best for YOU.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ Last edited by harrysin; 06-13-2009 at 12:59 AM. | ||
| | #6 (permalink) | ||
I took the spring out of my router, but it is a dedicated table router. It makes it much easier to adjust without the spring. The manual also said to take it out if it were going under a table. For the hand held one, I left the spring in. | ||
| | #7 (permalink) | ||
For hand held use Nick, It's essential to have the springs in place so that if anything goes wrong, the cutter will be safely returned to the housing.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #8 (permalink) | ||
There is no one correct answer since all routers are different. Which model do you have Tom? That is the key to getting a good answer.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #9 (permalink) | ||
| Registered User ![]() Join Date: Jan 2007 Location: Jerrabomberra, NSW, Australia First Name: Eddie Posts: 16 ![]() |
I took the springs out of my table mounted router, makes it easier to adjust height wise, plus with the springs in, it kept lifting the router plate when the fence was removed off of it. So I say springs out. | ||
| | #10 (permalink) | ||
Mike, I guess I should have been a little more specific with my post. I was curious about what others did and why. I currently use the Hitachi M12V and I removed the springs. Previously, I used a Makita 3612, again no springs. I do not use a router lift or above the table adjustment. I removed the springs for ease of height adjustment. | ||
| Removing springs from a Bosch 1617EVSPK | sher622 | General Routing | 9 | 05-17-2009 10:49 PM |
| Removal of router springs for table use | pianoman8 | The Voting Booth | 20 | 11-09-2008 10:02 AM |
| anyone pull the springs out of a Porter Cable 890 plunge base? | paulcomi | Tools and Woodworking | 8 | 04-23-2006 05:26 PM |
| Router springs | garys | General Routing | 4 | 11-02-2005 06:37 PM |
| Springs for M12V | angus | Tools and Woodworking | 4 | 10-17-2004 05:59 AM |
