Help
What am I doing wrong?
This is a discussion on What am I doing wrong? within the Table-mounted Routing forums, part of the Routers category; I have my Ryobi router set up in the table now and grabbed my templates ...
Old 06-22-2009, 10:49 AM   #1 (permalink)
First Name: Don
Plagmar is on a distinguished road
Default What am I doing wrong?
Report Post Report This Post!
I have my Ryobi router set up in the table now and grabbed my templates and wood (Hickory) and headed for the table yesterday.
I thought I would start with a small piece, just in case something went wrong I could easily cut a new piece.
Everything is now secured and set using a flush trim bit, I fire up the router and begin.
Hmmmmmmm, quite what I was expecting. The gap between the bearing and the cutting portion of the bit is enough that I am just touching the top of the template and it digs in a bit. Also, it kicks back as well.
Two or three more attempts, same results. I tried to slow the router down a bit, take small swipes but same thing.
Don
Plagmar is offline
Old 06-22-2009, 11:18 AM   #2 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
Don,
You need to use a starting pin. To use a starting pin you contact the pin first and then ease the work piece into the bit from right to left, then you can remove the piece from the pin after you have started the cut. The pin is to give you something to help steady the piece and help prevent the initial kick back upon contact. Also you need to lower the bit to where only the bearing is contacting the pattern/template and prior to starting any bearing bit be sure to check the bearing for tightness. It can be quite a shock if the bearing comes off and tears up your piece as well as the template.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Old 06-22-2009, 11:24 AM   #3 (permalink)
First Name: Don
Hi George...
I'm not using a pin but just going straight in.
If I lower the bit to where the bearing (nice and free turning) is full on the template, the bit is below the top surface of the work piece which is why this is so frustrating.
Does this make sense?
Plagmar is offline
Old 06-22-2009, 11:35 AM   #4 (permalink)
levon's Avatar
First Name: levon
levon is on a distinguished road
it sounds like you have a very thin template? the bearing is less tha a quarter in thick. also if the top of the cutter isnt slightly above the workpiece it will bind and kickback. that happened to me the first couple of times i tried to flush trim something. i also wonder if you are routing a male a or female template and your feed direction?
p.s. you might want to check and see if there are some spacer washers between the bearing and bit.
hopefully somone can give you a better answer than me.
levon
levon is offline
Old 06-22-2009, 11:46 AM   #5 (permalink)
First Name: Don
Unfortunately, it is a 1/8" template I'm using which is what I suspected at first.
Male/female template? I'm afraid to bite on this one.....
Plagmar is offline
Old 06-22-2009, 11:50 AM   #6 (permalink)
levon's Avatar
First Name: levon
a male termplate, you route around the outside and a female template, you route around the inside of the template. feed direction is reversed on the inside o the template. im not knowledgeable enough to trust myself using a template that thin.
levon
levon is offline
Old 06-22-2009, 11:56 AM   #7 (permalink)
First Name: Don
I thought the male/female thing was a noob setup joke, sorry...
It's a male template.
I can easily transfer the template over to a 1/4" piece and try again. It would be a helluva lot faster than sanding.....
Plagmar is offline
Old 06-22-2009, 12:12 PM   #8 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Plagmar
"it kicks back as well " it sounds like you running the stock the wrong way by the bit..
Someone of the forum said it just right,run the stock by the bit " like your read"
Don
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-22-2009, 12:19 PM   #9 (permalink)
First Name: Don
Running the piece right to left against the turning bit...
Plagmar is offline
Old 06-22-2009, 05:08 PM   #10 (permalink)
Twill57's Avatar
Twill57 is on a distinguished road
The first thing I thought of was, your wood is hickory. Hickory can cause you some problems when routing, it splinters and will grab the bit. Make sure you cutter is very sharp. Also, make sure you are cutting with the grain and not against it.
I would also make the template out of something thicker for the bearing to ride on.
Gather some scrap and practice using different feed rates and cutter speed and see what works.
I learned the hard way that dull or cheap router bits do not cut hickory well.
Twill57 is offline
What's wrong with this box? brucio Wood Scrolling 12 04-20-2009 07:37 AM
tear out - what went wrong ? jkristia General Routing 11 03-27-2009 03:08 PM
What am I doing wrong? Lokheed General Routing 13 08-17-2007 08:32 PM
Making a template, where did I go wrong? Thom2 Guide Bushings and Templates 10 08-09-2007 07:54 AM
Things wrong with site trap Lobby 14 07-25-2005 12:36 PM
