| This is a discussion on Bent wrench, Cranked spanner within the Table-mounted Routing forums, part of the Routers category; How do I go about making my bent spanner? I nearly chipped a cutter today, ... |
| | #1 (permalink) | ||
| Registered User ![]() |
How do I go about making my bent spanner? I nearly chipped a cutter today, adjusting the collet in the table from above. There do not seem to be any bent spanners in the U.K. Are the bought ones of flat sheet steel or forged? | ||
| | #2 (permalink) | ||
| Forum Contributor ![]() |
Hi Mike The easy way to have one is to make your own,,,many ways to do that.. You can use a service tool ( flat steel one that comes with many tools ) or a old wrench ( the shorter the better) grind the wrench out a little bit to fit the nut then put some heat to it and make it offset ..( Z wrench ) You can buy them on line in the states but the shipping may kill that to the UK ... ![]() ===============
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 06-23-2009 at 05:32 PM. | ||
| | #3 (permalink) | ||
Did you manage to solve the cranked spanner problem? If so how? | ||
| | #4 (permalink) | ||
Recently, I have been using straight bits smaller than 20mm dia. I use the Box/tube spanner. I am on the lookout for a flat spanner to adapt and bend. I am not paying $20 for a piece of bent steel. I will be getting a pair of collet extenders from MLCS soon. | ||
| | #5 (permalink) | ||
Could use a crows foot ratchet attachment as well. | ||
| | #6 (permalink) | ||
Hi I wish ![]() ==
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #7 (permalink) | ||
I had an extra Makita collet wrench. All I did was place it in a vice with wood blocks and bent/ hammered it to a 90°, flipped it over, did it again with about a 1" offset. Took me about 5 minutes, been using it for years.
__________________ "I don't believe anything, but I have a lot of suspicions" -R.A.W. | ||
| | #8 (permalink) | ||
| | #9 (permalink) | ||
I won a Mercedes-Benz chrome-vanadium, forged black spanner on ebay for £0.99p. Put it in the vice, pointed the oxy-acetylene torch on it, bent it by gloved hand, Repositioned it in the vice and repeated for the second bend. Excellent. Just make sure that you bend it near the head, otherwise it won't fit in the table insert plate recess. I have a 3 1/2" recess, so it is quite large. | ||
| | #10 (permalink) | |||
Hi Mike You don't need to buy one just use the one that came with the router,just a little heat and a vise and bend it over into the Z shape. ![]() But clamp the open part of the wrench 1st. and heat that point 1st. be sure to stick it in some water after... ======= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 01-28-2010 at 12:32 PM. | |||
| Offset Wrench | istracpsboss | General Routing | 5 | 05-04-2009 12:52 PM |
| Two wrench method- one wrench router | Delta6mike | General Routing | 63 | 12-01-2008 11:52 PM |
| home made spanner | harrysin | Lobby | 16 | 11-30-2008 10:22 PM |
| Bent my collet | nurumkin | General Routing | 6 | 06-27-2008 12:50 AM |
| Hitachi MV12 two wrench system | cbsjoez1935 | Table-mounted Routing | 15 | 04-22-2007 05:51 AM |
