Help
23 ga Pinning into MDF edges?
This is a discussion on 23 ga Pinning into MDF edges? within the Table-mounted Routing forums, part of the Routers category; I'm aware of the warnings not to screw into the edges of MDF, due to ...
Old 06-24-2009, 03:23 PM   #1 (permalink)
BigJimAK's Avatar
BigJimAK is a name known to allBigJimAK is a name known to all
Default 23 ga Pinning into MDF edges?
Report Post Report This Post!
I'm aware of the warnings not to screw into the edges of MDF, due to splitting. Do the ultra-small 23 ga. pins cause the same problem? I'm thinking of them as "temporary clamps" should I decide to glue hardwood edges to the edges of a MDF router table.
Has anyone here tried this?
Jim
Alaska's North Slope: One of the few places in the U.S. where when two people casually talk about the temperature getting "down to 40", both know that means -40F! Brrrrr...
BigJimAK is offline
Old 06-24-2009, 04:37 PM   #2 (permalink)
Mike Wingate's Avatar
First Name: mike
Mike Wingate is on a distinguished road
Forget the pins and screws. Go with glue and clamps.
Mike Wingate is offline
Old 06-24-2009, 04:52 PM   #3 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Jim
I use them all the time,the pictures is a little fussy but I think you can make it out ,it's 1/2" thick MDF wirh 17 nails in the edge,I did put some on a angle so you can see them and pulled the presser down to 2 lbs, psi. ,1" long pins..I do it all the time with 1/4" thick MDF also
The last picture is 1/2" MDF with only 3 brad nails and it split it like a walnut
Hope this helps
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-24-2009, 05:12 PM   #4 (permalink)
First Name: mike
How about biscuits or dowels?
Old 06-24-2009, 05:22 PM   #5 (permalink)
bobj3's Avatar
Hi Mike
I call them junk fasteners ,if I want the joint to turn I use a round dowel pin (so it break lose ) ,if I want the joint to swell up I use biscuits...then when the glue drys out you end up with a little dent in the stock
I should say I do like square dowel pins
"It's fine to disagree with other members as long as you respect their opinions."
MIKE
Senior Moderator
Part Finder
Bob J.
Old 06-24-2009, 05:35 PM   #6 (permalink)
Mike will become famous soon enough
23 gauge pin nailers let you do things you can't with other fasteners. It is worth buying one of these tools. I am sure BJ will agree they make life much easier.
Old 06-24-2009, 05:47 PM   #7 (permalink)
bobj3's Avatar
Hi Mike
I do,anytime you can do it without clamps your money and time a head of the job..
Part Finder
Bob J.
Old 06-24-2009, 07:45 PM   #8 (permalink)
BigJimAK's Avatar
Thanks, all! It sounds like time to add one to my shopping list!
BigJimAK is offline
Old 06-24-2009, 08:08 PM   #9 (permalink)
bobj3's Avatar
Hi Jim
I suggest the one below. it's not the high end one but it works great and at the right price, I like the slider on the side that helps select the right pin nail, quick and easy
Amazon.com: Grip 23 Gauge Pin Air Nailer Gun: Home Improvement
http://www.amazon.com/s/ref=nb_ss_hi...er&sprefix=pin
Part Finder
Bob J.
Old 06-24-2009, 09:24 PM   #10 (permalink)
RustyW's Avatar
First Name: Rusty
RustyW will become famous soon enough
I picked up this one a few days ago
- Harbor Freight Tools - Quality Tools at the Lowest Prices
It was $2 more in store but print the page take it with you and they will match it. I know it's HF, but I also have their $20 nailer/stapler. And both guns work fine.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Good source for precision straight edges? Nickbee Tools and Woodworking 0 02-01-2008 03:06 PM
Leigh Jig & Tails on Edges (vs. pins) FlyMaster Jigs and Fixtures 2 10-16-2007 11:10 AM
Carvewright 45 Degree edges dadsalmon General Routing 14 07-10-2007 10:43 AM
