| This is a discussion on t track mounting within the Table-mounted Routing forums, part of the Routers category; I'd like to ask a couple of follow-up questions. If the top you are putting ... |
| | #11 (permalink) | ||
| Registered User |
I'd like to ask a couple of follow-up questions. If the top you are putting the dado in is already laminated with plastic, do you have to do anything different? Or just cut the dado as you would if it were not laminated. And when using cement to attach the track to the MDF, what kind of cement? Thanks. | ||
| | #12 (permalink) | ||
| Retired Moderator ![]() |
Bert, the process is identical... the router bit does not mind having a bit of high pressure laminate for breakfast. You will get a nice clean cut. To glue the aluminum to MDF I suggest a thin epoxy.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #13 (permalink) | ||
| Forum Contributor ![]() |
Some suggest that the first cut be a VERY LIGHT one to score the laminate. It helps to prevent chipping.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| Centering your router on a mounting plate | Mike | Table-mounted Routing | 9 | 08-27-2009 12:59 AM |
| T track sourcing | westend | Tools and Woodworking | 12 | 06-22-2009 10:56 AM |
| Shop Fox W1728 router mounting issues | SkidSTL | Tools and Woodworking | 6 | 03-04-2009 06:42 PM |
| Mounting a router to a table mounting plate | rberry | Starting Off | 8 | 06-14-2008 10:24 PM |
| Mounting Bosch Jigsaw to Router Baseplate - finished | Ladd | Table-mounted Routing | 4 | 02-06-2008 05:47 PM |
