Help
t track mounting
This is a discussion on t track mounting within the Table-mounted Routing forums, part of the Routers category; are there any videos on how to do this ? I know its pretty straight ...
Old 06-29-2009, 12:39 PM   #1 (permalink)
uncleglenny is on a distinguished road
Default t track mounting
Report Post Report This Post!
are there any videos on how to do this ? I know its pretty straight forward would just like to see it done before i attempt.
uncleglenny is offline
Old 06-29-2009, 03:56 PM   #2 (permalink)
Mike will become famous soon enough
This is one of the easiest jobs you can do with your router. You cut the slot, then you fasten the track in place with small phillips screws. You will not need a video to get this to turn out.
Old 06-29-2009, 07:47 PM   #3 (permalink)
BigJimAK's Avatar
BigJimAK is a name known to allBigJimAK is a name known to all
Two suggestions:
Use an edge guide
Ensure the metal track is slightly below the table top, to avoid scratching your wood.
Alaska's North Slope: One of the few places in the U.S. where when two people casually talk about the temperature getting "down to 40", both know that means -40F! Brrrrr...
BigJimAK is offline
Old 06-29-2009, 09:26 PM   #4 (permalink)
First Name: Lance
westend is on a distinguished road
Are you cutting the track into laminate, wood, or....? IIRC, I used a spiral upcut bit and took a small amount of material with each pass. This was in a top made of MDF and laminated. I didn't use screws, electing to glue the track in place.
Sawdust is not dirt
westend is offline
Old 06-30-2009, 01:01 AM   #5 (permalink)
jschaben is on a distinguished road
The only problem I ever ran into was one setup where I was using homemade nutplates to attach a jig and found the counter sink for the screws was not quite deep enough to allow the nutplates to pass smoothly. I simply deepened the countersinks, using adhesive would have avoided the problem completely and, IMHO, if you are mounting it in MDF, adhesive would be the preferable option.
John Schaben
"I haven't failed, I have simply discovered several hundred ways that don't work"
jschaben is offline
Old 06-30-2009, 08:40 AM   #6 (permalink)
GBM
GBM is on a distinguished road
Wouldn't a downcut spiral make a cleaner cut on the top ( working ) surface ?
Not sure I am visualizing the physics correctly...
GBM is offline
Old 06-30-2009, 09:48 AM   #7 (permalink)
First Name: Lance
I don't know if the spiral direction makes that much of a difference. The fluting being at an angle is the key. One could use a straight bit, for that matter. If handled correctly, it should cut fine. I only had an upcut bit in the size needed for the track. IIRC, I cut the slots in the cheeks of the fence with a straight bit.
Sawdust is not dirt
westend is offline
Old 06-30-2009, 10:10 AM   #8 (permalink)
I just used a 3/4 straight bit on laminate covered particle board, some scrap kitchen countertop material. Didn't experience a lot of chipping, but then again I didn't examine it very closely as my priority was for it to be straight and tight fitting.
John Schaben
jschaben is offline
Old 06-30-2009, 04:26 PM   #9 (permalink)
a1tomo's Avatar
a1tomo is on a distinguished road
Like a few others, I used cement to attach, mostly because my tops have all been MDF.
I've reached the age where the "happy hour" is a nap!
Regards, Tom
a1tomo is offline
Old 07-02-2009, 07:43 PM   #10 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
Just route a dado, slip the T-track in it, and screw it down. The screws don't have to be too tight as friction will hold everything in place when you tighten something into it.
AxlMyk is offline
Centering your router on a mounting plate Mike Table-mounted Routing 9 08-27-2009 01:59 AM
T track sourcing westend Tools and Woodworking 12 06-22-2009 11:56 AM
Shop Fox W1728 router mounting issues SkidSTL Tools and Woodworking 6 03-04-2009 07:42 PM
Mounting a router to a table mounting plate rberry Starting Off 8 06-14-2008 11:24 PM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 06:47 PM
