| This is a discussion on help please within the Table-mounted Routing forums, part of the Routers category; hi there got a router and table of a mate,tried to use it yesteday but ... |
| | #1 (permalink) | ||
| Registered User ![]() |
hi there got a router and table of a mate,tried to use it yesteday but when i press the green button on the table nothing,but if i go under table and press the button on the router it works am i missing something or do i have to somehow make something to keep the button down? any ideas would be great | ||
| | #2 (permalink) | |||
| Forum Contributor ![]() |
Hi tosha It's a real PITA when the router is setup that way..pull some elec.tape out of the tool box and tape the switch down,,,so it's on all the time.. If you want to take the router the out, you can open it up and by the switch but I don't recommend doing it that way...the tape is a easy and quick fix.. ========= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #3 (permalink) | ||
| Retired Moderator ![]() |
Hmm, (Your name here) it sounds like you are from Oz and own a Triton router?
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #4 (permalink) | ||
| Official Greeter ![]() |
Greetings (your name) and welcome to the router forum.
__________________ Wisdom: Where experience and knowledge combine and become one. "We are all one decision away from Stupid!!" Lamentations 3:22-23 "How often we sacrifice the permanent plans of God on the altar of immediate solutions" I have a very good memory, just short is all. | ||
| | #5 (permalink) | ||
| Moderation Team ![]() Join Date: Mar 2009 Location: Anchorage, Alaska First Name: Jim Posts: 2,058 ![]() ![]() |
Greetings and welcome, tosha. Bob is spot on! ![]() Jim
__________________ Alaska's North Slope: One of the few places in the U.S. where when two people casually talk about the temperature getting "down to 40", both know that means -40F! Brrrrr... | ||
| | #6 (permalink) | ||
Sorry Mike but it's only the Triton saw that needs it's switch held on with a Velcro strap, in any case it isn't green! But you were close.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #7 (permalink) | |||
If you could tell us the make or model of the router, some one will be able to put forward a solution to your problem. It seems the router switch needs to be locked on in some way. James | |||
| | #8 (permalink) | ||
Sorry Harry the push button switch on the external box IS green.
| | #9 (permalink) | |||
I seem to be missing a lot here. Is the green button still on when you press the button on the router? What is the router plugged into? What is the make and model of the router? ![]() Cheers
__________________ John Schaben ![]() "I haven't failed, I have simply discovered several hundred ways that don't work" | |||
| | #10 (permalink) | ||
My apologies Mike, I must be catching it from you! This shot shows how I lock the switch on my Triton saw.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ Last edited by harrysin; 07-05-2009 at 08:18 AM. | ||
