Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 09-26-2005, 08:37 AM   #1
TOMW.
New Member
TOMW. is on a distinguished road
Question Burn Marks
I was wondering if anyone knew of any sure-fire ways to NOT get burn marks in the curves of the peices I'm routering. I am tired of spending 30 minutes or so trying to hand sand out the burns, it's costing me $$$. PLEASE HELP!
TOMW. is offline   Top - Reply with Quote
Old 09-28-2005, 03:51 PM   #2
wbush@direcway.com
New Member
wbush@direcway.com's Avatar
wbush@direcway.com is on a distinguished road
Hi Tom,
I hope this helps but I've found two reasons for burn marks on routered wood. One is a dull bit and the other is not moving the material along fast enough past the bit.
Hope this helps.
Walt
wbush@direcway.com is offline   Top - Reply with Quote
Old 10-01-2005, 10:46 AM   #3
TOMW.
New Member
Originally Posted by wbush@direcway.com
Hi Tom,
Hope this helps.
Thanks, I'll tryto move a bit faster. I have some wood splitting problems when I go too fast, but I'll try to find a happy medium. I just put a new bit on there as well, so hopefully I can get the hang of it.
Thanks again.
Old 10-02-2005, 03:55 AM   #4
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
Hi TomW,
You might try taking 2 passes if your work is splitting out. Usually if your router is up to speed, and you score your work with a lighter cut first, you won't have a splitting out problem. However, some woods are prone to splitting, especially if you are cutting against the grain.
Good Luck......Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Burn marks rosq General Routing 5 10-31-2007 08:03 PM
now im bummed... unlimitedwoodworker Lobby 4 10-06-2007 10:08 PM
David Marks Show... challagan Guide Bushings and Templates 5 04-15-2007 04:24 PM
erasing pencil marks on projects Joe Mulherin Tools and Woodworking 1 08-20-2006 02:54 PM
Burn burn Introductions 3 12-24-2005 12:38 AM
