Help
Using Bob's Box Joint / Dovetail Jig
This is a discussion on Using Bob's Box Joint / Dovetail Jig within the Table-mounted Routing forums, part of the Routers category; I have been salivating over the Oak Park jigs for making Box Joints and Dovetails. ...
Old 10-08-2005, 12:16 AM   #1 (permalink)
fibertech's Avatar
First Name: Derek
fibertech is on a distinguished road
Send a message via AIM to fibertech
Default Using Bob's Box Joint / Dovetail Jig
Report Post Report This Post!
I have been salivating over the Oak Park jigs for making Box Joints and Dovetails. I want to know if anyone has used them on another type of table? I have a Rockler table that I like very much. The Oak Park jig looks very easy to use. Do I need to drill holes in the tabletop? Any experience is appreciated. -Derek
fibertech is offline
Old 10-08-2005, 09:25 AM   #2 (permalink)
The box joint jigs are very good,but the dovetails that can be made are not for putting two boards together at a 90 degree angle(such as a drawer).
regards
jerry
jerrymayfield is offline
Old 10-08-2005, 09:56 PM   #3 (permalink)
fibertech's Avatar
First Name: Derek
I may have been unclear. In the OakPark catalogue, the plastic jigs are pre-drilled to fit their table. Would it be worth my effort to buy those jigs and retrofit my table? -Derek
Old 10-09-2005, 09:49 AM   #4 (permalink)
I have a set of the spacer fences,1/4-3/8-1/2, they are very good for making box joints and what they call a combination joint. I didn't drill holes in my table,have always used clamps, but the holes would probably be better.With a little practice they are easy to use and get good box joints. My only suggestion would be to go to Enco or another industrial supplier and purchase some solid carbide spiral end mills. They cut beautifully and cost less than router bits.
Good Luck
Jerry
Old 10-09-2005, 08:24 PM   #5 (permalink)
Visteonguy's Avatar
Visteonguy is on a distinguished road
try looking on Ebay ,,, quite often they are even less..
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline
Old 10-11-2005, 02:05 PM   #6 (permalink)
kp91's Avatar
First Name: Doug
Please check speed ratings on any bit, cutter or end mill you might chuck up in your router. Remember, most milling machines are designed with speeds under 5000 rpm, where routers run 10-20,000 rpm. I'd hate to hear about anyone hurting themselves to save $10.
1 John 1:9
http://instaverse.com/
kp91 is offline
Old 10-23-2005, 07:22 AM   #7 (permalink)
deanj is on a distinguished road
Wink
Safety is number one always. Good job kp
deanj is offline
Not bad joint Benny LaBaw Lobby 12 02-02-2008 12:07 AM
Dovetail Depth of Cut Sherwood Portable Routing 5 09-15-2007 10:28 AM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
Adapting Bob's Box Joint Jig to a Rockler Table fibertech Table-mounted Routing 8 04-22-2006 11:35 PM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 01:50 PM
