| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User | Hello - last year I made several simple bookcases. They are wall cases, approx 82" tall...10"pine sides and tops, same sized shelves evry 11 inches. I bought a craftsman router to channel out the slots on each side of the uprights to fit the shelves into. The problem is that I freehanded the router for each cut, and they arent as straight as I would like...is there a way to use a router table or other tool to ensure straight cuts? thanks. |
| | #2 | |
| Retired Moderator Forum Geek | Quote:
Hello mike222, Welcome to the RouterForums ![]() Yes there is a way to route dadoes for shelves. You can use a straight edge. I use a 10 foot 2 piece aluminum straight edge clamped to the wood on both ends when cutting dadoes with my router. Or you can use the straight side of a piece of plywood or any straight edge. I picked mine up from Ace hardware I also use it for cutting the full length of a sheet of plywood with my circular saw. There are also jigs that some build, or buy to use for this. You can do a Google search for cutting dadoes. Here is a link to Router Dado Jig from ShopNotes web site.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ | |
| What project are you in the middle of? | Bob | Tools and Woodworking | 11 | 06-11-2007 11:57 PM |
