| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | is there a right way on how to read a tape measure? i've seen a lot of different ways on how to read a tape measure so wich way is the right way? ![]() |
| | #2 |
| Marine Engineer Forum King | Biggest thing with tape measures is making sure that you are parallel with the edge you are measuring. It is amazing how having the tape at a slight angle can throw off the measurement, especially over a longer distance. The clip end also has to move, it slides in for inside measurements, out for outside measurements to compensate for the width of the clip. However, if the clip is bent, or the tape has been abused, those holes might be too large, and you're going to introduce some error. Treat your tapes nice, and they'll be reliable much longer. I use tape measures for 'coarse' measurements and if I need something more exact I use my scales. This works great for smaller parts, which are often hard to measure and mark with a tape, and for machine setup. I also use a 6 inch dial caliper if I want really accurate measurements of small stuff, and brass guage blocks like the router guys use for tool setup. A decent dial caliper is often under $20. Of course, my scales only go up to 2 feet, so if I'm over that I have to either improvise, transfer the measurements to story sticks, or trust a tape. If I need an accurate measure from a tape, I usually start at the 10 inch mark and work from there. That removes the end from the equation, and hopefully some of the error. Also, to improve accuracy using only a tape, stick with one tape measure for the entire job. I've found in the past that some of my tapes do not agree exactly, and if your using one at the bench to lay out your parts, and one over by the table saw to check the parts after the cut, you could be chasing your tail. As big a deal as reading a tape is putting your pencil mark on the board. A hastily drawn mark can be confusing as soon as you pull the tape away. I like to use 5mm pencils and make a 'v' at the mark, instead of just a dash.
| | #3 |
| Registered User Supreme Forum King | |
| | #4 |
| Registered User New Member | LOL....ok maybe i worded it wrong I SOMETIMES DO THAT....lol i understand the half inch mark and the inch mark but WHAT are the little marks inbeween them ARE THEY AN EIGHTTH OF AN INCH OR WHAT? if your still confused let me know and i'll TRY& explain it better. ![]() |
| | #5 | |
Ed | |
| | #6 |
| Registered User Jr. Member | Reible, I have been around the world a couple of times but I have never seen an "Image Tape"! I like that ... where can I find one? Thanks Leo |
| | #7 |
| Registered User Supreme Forum King | www.mcfeelys.com or page 62 in the catalog #05j Right / Left tape measure fsc-4020 (16') $9.95 fsc-4021 (25') $11.95 Ed |
| | #8 |
| Registered User Jr. Member | Thanks Ed ... I ordered a 25Ft. Leo Last edited by em14; 11-19-2005 at 12:56 PM. Reason: Opps I misspelled! |
| [FAQ - Information] Reading and Posting Messages | Mark | Forum Help & FAQ | 0 | 02-24-2007 06:49 PM |
| Double Sided Tape? | Router is still my name | Portable Routing | 7 | 05-04-2006 07:00 PM |
| double sided tape? | falcn63 | General Routing | 4 | 01-17-2006 02:48 PM |
| Brads VS. Double Sided Tape | Pop_pop1 | Jigs and Fixtures | 8 | 08-18-2005 06:11 AM |
| double stick tape | trap | Tools and Woodworking | 7 | 02-17-2005 02:59 PM |
