| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Dedicated Member | OK, I've got to make up some glass panel doors, I need to find a glass panel door bit set. Any suggestions?? Cheers! |
| | #2 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,787 ![]() | I did a quite google query and my results turned up: http://www.woodtechtooling.com/CMT/r...#GlassPanelSet hopefully that helps.
__________________ Mark, Administrator and Technician of RouterForums.com RouterWorkshop.net - Get more out of your router! |
| | #3 |
| Registered User Forum Geek | If you have the bits for cutting the stiles and rails all you need is a rabbeting bit to cut the back for the glass panels. The few times that I have done this I used the stile cutting bit to mold both edges of some spare door stock.cut these free on the table saw and this molding was used to hold the glass in. Gives a nice finished door on both sides. Regards Jerry |
| panel doors actual photo of different profiles | sammy57 | Router Bits - Types and Usage | 4 | 03-11-2008 06:15 PM |
| Reproducing a panel moulding on existing doors | paulcomi | Table-mounted Routing | 3 | 06-29-2007 01:35 PM |
| research for raised panel doors | presumed_druid | Table-mounted Routing | 4 | 01-13-2006 11:47 PM |
| rasied panel doors | jce | Table-mounted Routing | 6 | 12-13-2004 01:45 PM |
| Cedar raised panel doors | fred m deolick | General Routing | 15 | 10-08-2004 12:02 AM |
