The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page Mortise & Tenon System Router questions
Table-mounted Routing Discuss Mortise & Tenon System Router questions in the Routers forums; I'm looking at buying the Mortise & Tenon System from Oak Park.(since it's on sale..) I currently ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 11-16-2005, 01:04 PM   #1
kenadian
Dedicated Member
kenadian's Avatar
User Info
Trader Rating: (0)
Gallery: View
kenadian is on a distinguished road
Default Mortise & Tenon System Router questions
Send Private Message | View Profile
I'm looking at buying the Mortise & Tenon System from Oak Park.(since it's on sale..) I currently have a Hitachi M12V mounted in the table; I also have a B&D RP200 1 3/4 HP 1/4" plunge router......
My question is will the B&D RP200 be OK(power wise/shank wise) for doing the mortising? Since I have this router, I would like to use it with the 7" base plate,[that comes with the Mortise & Tenon System] rather than switching out the M12V from the 11 " table plate to the 7" plate for mortising... Is the mortising done with a 1/4" bit as well?
All comments are welcome.....
I am Kenadian!
kenadian is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 11-17-2005, 10:20 AM   #2
jerrymayfield
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
I don't have any experience with a b&d router but if is 1 3/4 hp you shouldn't have problems. If you are working with 3/4 " stock most mortises will be 1/4 " width. If you don't already have one buy a 1/4 " SC upcut spiral bit. They are great.
Regards
Jerry
jerrymayfield is offline   Top | Reply with Quote |
Old 11-17-2005, 03:22 PM   #3
Woodnut65
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
Woodnut65 is on a distinguished road
Hi: The only size mortise the Oak-Park system makes is 1/4", your 1 3/4 Hp router should do it easy. The tenons are cut on the router table with the supplied fence and guide block. The 7" plate gets two bearings one in either corner of the plate, it will center the router bit to cut the mortise. Hope this helps you out.. Woodnut65
Woodnut65 is offline   Top | Reply with Quote |
Search this Thread:
Advanced Search
Mortise & Tenon Jig for the Plunge Router bobj3 Jigs and Fixtures 39 05-22-2008 08:57 AM
Making Mortise with a router table thdewitt Table-mounted Routing 9 07-16-2007 09:40 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
mortise and tenon system kellyp Jigs and Fixtures 1 02-15-2005 03:36 PM
Mortise and Tenon Joints TheVogon Table-mounted Routing 3 09-28-2004 10:15 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
