Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 12-29-2005, 01:38 PM   #1
beelsamin
beelsamin is on a distinguished road
Default Mastercraft router base plate
Hello,
I received a Wolfcraft 490 router table for Christmas and quickly found that the base plate adapter included with the table would not fit my Mastercraft(model 54-69096) plunge router. Does anyone have any ideas on how to resolve the adapter problem....so far the only solution I can think of is going out and buying a new router...and I hate to waste money on duplicate tools.
beelsamin is offline   Top - Reply with Quote
Old 12-29-2005, 05:54 PM   #2
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
Yeah, that's something that you might have to do unless you want to return the router table and get a different one. Hopefully one that would work. If you do decide on getting another router, just make sure you get one that matches exactly or you might end up with the same problem. Also, it's not too bad to have duplicate tools. One you can use for hand held and the other for table only. Just a thought...
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline   Top - Reply with Quote
Old 03-15-2006, 02:03 PM   #3
Cassandra
Sr. Member
Cassandra is on a distinguished road
Hi Beelsamin:
I am new here and found your question.
Basically, my father and I recently bought a Wolfcraft 490 to use with our Mastercraft plunge router. Like you, we found the mounting template to be incompatible with the router. So, we made our own template.
Using a piece of MDF of the same thickness as the supplied mounting template, we did the following:
1. Fastened the supplied mounting template to the MDF.
2. Using a template-following, striaght bit in the router, we routed the inside and outside of the template, making the MDF board the same as the supplied template.
3. We then created countersunk holes for mounting the routher to the new template.
We fastened the new template to the router and then to the Wolfcraft table. Works a treat.
Cassie
Cassandra is offline   Top - Reply with Quote
Old 03-16-2006, 07:21 AM   #4
del schisler
Forum Geek
del schisler is on a distinguished road
i have a few tables and like you found the pc690 didn't fit the wolfcraft so i took the base plate and put it over the hole in the table and just drill new holes and countersink the bolt holes and it works dont use this table much i use the one that is made by oak park
del schisler
del schisler is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Model 320.17542 and table routing trap Table-mounted Routing 41 07-03-2007 12:37 PM
Rousseau 3509 9" x 12" x 3/8" Deluxe Router Base Plate deck99 Table-mounted Routing 14 01-20-2007 12:31 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 11:37 PM
