Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-03-2006, 08:53 PM   #1
Bub
New Member
Bub is on a distinguished road
Default Brass guides
Oak Park currently has them on sale - 12 bucks ea. Would be fine to have all sizes but....what are the most usual sizes, most commonly used? Thanks.
Bub is offline   Top - Reply with Quote
Old 01-04-2006, 03:48 AM   #2
template tom
Forum King
Hi Bob
What is the largest guide offered?
Tom
Old 01-04-2006, 02:58 PM   #3
Bub
New Member
Hi Tom - largest is 1 1/2" o.d. all the way down to 1/4".
Old 01-04-2006, 06:59 PM   #4
template tom
Forum King
That looks like 37mm as the largest which is good as other set that I have seen is about 20mm being the largest. During my time doing demonstrations at wood shows I was constantly asked 'Why do you need a 40mm Guide'?
Four simple answers were given.
1/ A greater range of cutters can be used
2/ You can see most of the cutters in action during the process
3/ The 'Swarf' will dispell more easily and not build up and overheat the cutter
4/ The most important Small 1/4" cutters which are usually small in length can be used with greater safety as the router chuck will penetrate through the guide to give the depth required.
There was a fifth reason I added lately but I do not recall it at this stage (Old Age)
You will also require other size guides. The more guides you have will increase the number of projects that you can complete.
My preference is to use metric guides and metric cutters as it is much easier to do the calculations No 64ths 32nds 16ths etc.
Just a note I do all my template guide work in the plunge mode. Over the year I have submitted pics to the forum all projects are completed with the use of the guides for at least 90% of the work.Hope this information has been of help to you
Tom
Old 01-05-2006, 08:55 PM   #5
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
The one's I order last week are on back order.
Old 01-05-2006, 10:37 PM   #6
kp91
Forum King
kp91's Avatar
First Name: Doug
lee valley usually has sets of the larger diameter (not porter cable size) for around $20. My 1 in, 3/4, and 1/2 see the most use.
http://www.leevalley.com/wood/page.a...000,51208&ap=1
1 John 1:9
Old 01-06-2006, 05:16 AM   #7
KenW
New Member
KenW's Avatar
KenW is on a distinguished road
Default You might check out
Infinity Tools was offering a set of brass guides free if your order was over $50 (I think it was 50). It was a ten piece set and Porter Cable friendly. I'm not sure how long the special lasted but you could easily check the website. I have used their bits in the past and have had no problems with them, so the guides should be ok. Home Depot and Lowes also sell a similar 10 piece set.
KenW
KenW is offline   Top - Reply with Quote
40mm Guides for Templates + more bobj3 Jigs and Fixtures 30 07-23-2007 12:09 AM
1.5" brass guides routerman1969 The Bargain Bin 20 07-15-2007 10:32 PM
1 1/2 Brass guides MiamiSnookII Table-mounted Routing 2 01-08-2006 10:06 AM
Best way to center brass guides datafry Table-mounted Routing 2 11-01-2005 11:48 AM
Brass Router Template Guides Hermit Table-mounted Routing 4 05-30-2005 02:37 PM
