| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | Reading Bub's post on brass guides generated a few questions. I recently ordered the "build your own table set" from OPEL, as most of you know the base plate is 1 1/2 inch in diameter. After a brief search I noticed a limited supply of brass guides that fit a 1 1/2 inch hole, most were 1 3/16 and 1 3/4 inch. I have to assume that we can't use 1 3/16 due to the wiggle that will remain between the plate and the guide. Am I limited to having to buy brass guides from OPEL or is 1 1/2 a common guide opening and I just haven't found another source yet?? thanks, Peter |
| | #2 |
| Forum Moderator Supreme Forum King | Yes Pete you are correct. I went to put my 1 3/16 guide bushings into the opening and found that they don't work. Oak park sells the bushings I believe that fit in the 1 1/2 opening.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| | #3 |
| Registered User Forum Geek | The 1-3/16" pc guides are the most common guides and are available almost everwhere. You might want to consider making or buying another plate. The places I have seen the 1-1/2" guides are Oak Park & Lee Valley. Regards Jerry |
| 40mm Guides for Templates + more | bobj3 | Jigs and Fixtures | 30 | 07-23-2007 12:09 AM |
| 1.5" brass guides | routerman1969 | The Bargain Bin | 20 | 07-15-2007 10:32 PM |
| Brass guides | Bub | Table-mounted Routing | 6 | 01-06-2006 05:16 AM |
| Best way to center brass guides | datafry | Table-mounted Routing | 2 | 11-01-2005 11:48 AM |
| Brass Router Template Guides | Hermit | Table-mounted Routing | 4 | 05-30-2005 02:37 PM |
