Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-09-2006, 07:36 PM   #1
tsringcutter
New Member
tsringcutter is on a distinguished road
Default One piece stile & rail bit
I am looking to buy A one piece stile & rail bit (stacked) to use in my table mounted router. I see some have two bearings, one at the top and one at the bottom. Some have just one in the middle. Any advice on what to look for, one,two,or no bearings? I will be using it to make kitchen cabinet doors. Thanks.
tsringcutter.
tsringcutter is offline   Top - Reply with Quote
Old 01-10-2006, 06:50 AM   #2
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: The type of style and rail cutter with a bearing are used when using a template to do arched door rails. Bits without a bearing are used with a fence, for straight cuts without templates. Rails require a support when cutting them, like a sled. The important thing with one piece bits is that when you use them they allow both stiles and rails to be cut the same way, that is with the face down or up in both cases.
I use the bit sold by Oak-Park in the raised panel system and it works perfect.
Hope this helps answer your question.. Woodnut65
Woodnut65 is online now   Top - Reply with Quote
Old 01-10-2006, 10:28 AM   #3
jerrymayfield
Forum Geek
The two piece matched set works the same way both bits stock face down. Some of the adjustable bits Ive seen have two bearings, but I would think atleast one of them is usually removed before using. I have never used an adjustable stile and rail(cope & stick)
bit.
Regards
Jerry
Old 01-10-2006, 09:44 PM   #4
tsringcutter
New Member
Thanks that's what I was looking for.
Hi all -- rail and stile bit and 1/2" collet help! Bryan Introductions 14 11-26-2007 12:40 AM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 09:42 PM
Rail & Stile Dilemna sameerallidina@shaw.ca Table-mounted Routing 3 01-22-2007 03:49 PM
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 8 01-10-2007 12:07 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 08:53 AM
